**Ben Gromicko tears apart a mid-efficiency gas-fired heating system to demonstrate how impossible it is to inspect for a cracked heat exchanger during a normal home inspection.
That is a excellent video to show clients why we cannot inspect the heat exchanger. Although it would be priceless to see the looks on everyone’s faces if you did start tearing it apart. :shock:
Thanks - it was fun - I hope everyone takes advantage of the free video - it’s part of a larger course that is excellent.
1 - set expectations of your client
2 - there are many vital things that are simply beyond a visual inspection - and that’s okay
3 - use good narratives
4 - use good disclaimers
5 - learn more than you think you need to know
If you’re still having problems getting the video to play - click the link - then REFRESH your browser.
Good Video Ben, thanks. Since I started HVAC training this fall (evenings), I’m finding a lot of the same, and priceless, information that matches what you’re offering. Thanks for all you do to advance the interNACHI video training.
