Furnace & Water Heater Flue Height
Should the furnace & water heater flue be higher than the fireplace flue in this photo?
Several people looking at this, nobody has anything to say? :shock::shock:
Just looked at code check and in your pic they both look wrong if the furnace is below that roof over hang it should be 8 ft out from the over hang. or 2 feet above
Thanks, Charley!
Sure are a lot of these out there.
What was the distance from the chimney’s to the overhang?
Yes. It should be higher then fireplace flue. In your photo, its looking incorrect.
