Old 10/31/09, 8:26 PM
mbenerowski mbenerowski is offline
Please Note: mbenerowski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Gas line question/s
I did an inspection today on a custom home. The gas meter is on the south side of the home and on the north side of the home I found these shutoffs. I have a couple of questions.
1. Is this gas piping (flexible metal armoured piping) acceptable to be buried?
2. The mainfloor gas fireplace insert has a thinner bendable copper going through solid brick construction?
3. The lower basement gas insert has a flex black plastic tubing going through solid brick construction?
Thanks
Gas line question/s-p1030242c-jpg   Gas line question/s-p1030243a-jpg   Gas line question/s-p1030243d-jpg
Find an InterNACHI certified District Of Columbia Home Inspector (and anywhere else in North America)
Old 11/1/09, 1:13 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector
Default Re: Gas line question/s
I don't know Canadian requirements, but no, no, no.
The "flex" does not appear to be the traditional CSST, and looks more like an appliance connector.
Copper is not allowed in many jurisdictions, but OK in others.
Plastic is not allowed by any U.S. jurisdiction as far as I know.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/1/09, 6:46 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
If I came across this, I think I'd run!
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 11/1/09, 12:10 PM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
I have not done anything in Canada for about 12 years But i do not think things got change for natural gas, that would not be allowed.
Old 11/1/09, 2:59 PM
Ya I wrote it up as a immediate safety concern and refered to a licensed gas professional.
Old 11/3/09, 3:44 AM
Rick Maday's Avatar
Rick Maday Rick Maday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
http://www2.rigov.org/pdf/inspection...nalFuelGas.pdf
(pg 63)
403.6 Plastic pipe, tubing and fittings.
and fittings shall be used outside, underground, only, and shall
conform to ASTM D 2513. Pipe shall be marked “gas” and
“ASTM D 2513.”
403.6.1 Anodeless risers.
anodeless risers shall comply with the following:
1. Factory-assembled anodeless risers shall be recommended
by the manufacturer for the gas used and shall
be leak tested by the manufacturer in accordance with
written procedures.
2. Service head adapters and field-assembled anodeless
risers incorporating service head adapters shall be
recommended by the manufacturer for the gas used,
and shall be designed and certified to meet the requirements
of Category I of ASTM D 2513, and U.S.
Department of Transportation, Code of Federal Regulations,
Title 49, Part 192.281(e). The manufacturer
shall provide the user with qualified installation instructions
as prescribed by the U.S. Department of
Transportation, Code of Federal Regulations, Title
49, Part 192.283(b).
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing, Ethics & Legal Issues for Inspectors 52 7/11/17 4:34 PM
Slope of waste drain line. mlong Plumbing Inspections 7 12/12/16 3:25 PM
Main Line vs. Supply Line Reporting Details sshockley Plumbing Inspections 2 6/14/09 4:07 PM
Selected Electrical Incidents and Occurrences - First Quarter pabernathy Electrical Inspections 0 12/2/07 2:43 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 8:59 AM
