Old 2/12/10, 3:05 PM
Jim MacDonald Jim MacDonald is offline
Default A/C or Heat Pump
I'm just starting out. Can anyone tell me if there is a sure (easy) way to tell if a heat pump is installed?
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/12/10, 3:28 PM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
Default Re: A/C or Heat Pump
Jim Look at the condenser and look for the Reversing valve, and likley the thermostat will give you a hint.
Maybe take the nachi Course https://www.nachi.org/hvaccourse.htm
Old 2/12/10, 3:43 PM
Keith Runquist Keith Runquist is offline
Send a message via AIM to krunquist
In our climate the heat pump is always up off the ground to accomodate dripping and ice underneath. Also to keep it above the snow. They are typically about 1 foot off the ground on a stand.
Keith Runquist, CMI
A/C or Heat Pump-reversvalve-jpg
Old 2/12/10, 5:15 PM
Thanks Wayne. Very helpful. I will take the course. And thanks for the photo.
Old 2/12/10, 5:16 PM
Thanks as well Keith another very useful bit of info.
Old 2/13/10, 12:28 AM
Chuck Lambert Chuck Lambert is offline
Unmoderated Guest
Please Note: Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
The id tag usually states 'Heat Pump'
Old 2/13/10, 12:15 PM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
Certified Master Inspector
Running the heat, the condenser will be running.
Thermostat will have an "emergency" or "auxiliary" heat mode. Caveat: some heat pumps have been incorrectly installed with a traditional thermostat, and that would be wrong.
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Old 2/13/10, 3:04 PM
Kevin L. Luce Kevin L. Luce is offline
Please Note: kluce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Another indication is three ports to hook up the Freon gauges.
Where are you from?
Old 2/13/10, 3:08 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
http://www.midtninspections.com/blog?page=2
They all don't note "Heat Pump" on the data plate.
Thermostat should have an emergency/axillary heat option (but don't bank on it)!
Not all three ports are visible without pulling the unit apart.
Running in heat may not energize the outdoor unit (there is no condenser on a heat pump).
There is not always an accumulator.
As Wayne posted, look into the fan grill and look for the reversing valve.
That is the only sure way.
We use "refrigerant gauges", Freon is a manufacturer not the gas in the unit.
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 2/13/10, 3:35 PM
Man, you sound like a "glass that's half empty" type of person between what you just wrote and that article.
Air conditioning for residential is not an exact science and many methods I've seen used (that are a lot faster) puts those freon level and temperature drop right in that range.
The guy wants to be able to identify a heat pump. I think the suggestions we gave him are a great start to help him with his learning curve.
Old 2/13/10, 3:46 PM
I found this real quick. You can see the third port on the housing above and middle of the two freon lines.
In most cases, the third connection is accessible so the service tech or installer can hook that Freon hose to it. You might have to take off that service panel to see it.
A/C or Heat Pump-froen-ports-heat-pump-jpg
Old 2/13/10, 3:51 PM
Quickest thing is looking for the reversing valve it has been a rare event not seeing one.
BTW Try touching the suction line ( bigger line) if it is hot it is a heat pump ( if it is running that is )
Old 2/13/10, 6:57 PM
Oh but it "is" my friend!
Maybe you can use the temp drop in your neck of the woods, but humidity (which is latent heat) throws that stuff right out the window in many parts of the country.
You just do what you think is right for you.
As nowhere in any SOP is HVAC diagnostics part of Home Inspection, I think the new guys should think long and hard about it.
Most HI Law Suits are about HVAC stuff.
The temp drop works when the HVAC systems are deigned correctly in the first place. But a HI has no idea if this is the case.
At what friction loss do you design your HVAC systems?
How do you test for friction loss?
If this is not set up correctly, a thermometer tells you nothing.
BPI# 5015804
Old 2/13/10, 8:02 PM
[QUOTE]
It's been a while since I did heating and cooling but if I remember correctly, there was a +/- 3 psi when charging using the super heat method.
I agree with this statement. Even when a home inspector can discover something as simple as a dirty filter, there are other problems that can exist such as a dirty A-coil.
I wonder how true that is throughout the USA. In this area I was told it's foundation problems (example: water seepage).
I personally think that cost and homeowners wants will prevent getting the idea numbers. Is that person going to design a house or use the right components resulting in proper static pressure and velocity pressure = friction loss? I doubt it. Is that homeowner going to replace part if not all the duct when the new furnace is replacing that 40 year old one. I doubt it. That's why there is leeway.
O-well, It's 6pm and I got to get out of the office now and get home so my wife and I can enjoy a night out without the kids.
Good night all.
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing, Ethics & Legal Issues for Inspectors 52 7/11/17 4:34 PM
Heat Pump Check list for inspecting dmacy Inspecting HVAC Systems 24 4/22/15 12:55 PM
Radiant ceiling heat? bmargiotti Inspecting HVAC Systems 17 7/27/13 6:20 PM
Heat pump in a 80+ year old masonry house jskrypka Inspecting HVAC Systems 9 11/25/06 11:47 PM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 1:15 AM
