Old 12/8/12, 9:28 AM
Gary Heller's Avatar
Gary Heller Gary Heller is offline
Default heat pump cycling before reaching set point
Our new house has a Goodman 4 ton hp. We leave the unit off at night and house temp gets down to around 65 degrees and the outside temp is about 30 degrees. When we wake up I turn the unit on with a 70 degree set point. The unit will cycle several times prior to reaching an inside temp of 70 degrees. I've told the builder that this unit needs to be "trimmed". He disagrees. Should I be worried about "slugging" the compressor?
Gary Heller
928-910-9175
www.inspectingprescott.com
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/8/12, 9:45 AM
Charley L. Bottger's Avatar
Default Re: heat pump cycling before reaching set point
Not to worry about slugging the compressor, they are designed to operate in cold weather.
What do you mean cycle several times meaning into defrost or cycling off period before set point
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
Okla State License # 130
580-268-3340
Old 12/8/12, 9:56 AM
It will run about 10 minutes and cycle off. Then it comes back on for 10 or 15 minutes and cycles off again. At a 30 degree outside air temp I don't think it should go into a defrost mode that quickly.
Gary Heller
928-910-9175
Old 12/8/12, 10:51 AM
You have a problem Call a tech and send the builder the bill, or at least call the installing contractor and bypass the builder most contractors in my area place a sticker on the unit with their phome # the unit should still have a warranty.
580-268-3340
Old 12/8/12, 11:08 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
If the thermostat shuts down when the air temp at the thermostat has not reached set point; it is possibly the "anticipator" in the thermostat is not set right.
If the temperature reaches set point but falls quickly after shut down; the wall the thermostat may not be insulated and there is a bypass to the exterior.
Air stratification can occur and it is 100F at the ceiling and 40 at the floor. This will cause a short cycle.
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 12/8/12, 3:01 PM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Certified Master Inspector ®
Thermostats installed too close to register will cause that problem. I relocated mine away from the 50in. plasma.
On The Level Inspection
Gatineau, Québec
Improving a heat pump???? rcooke Canadian Home Inspectors 18 12/4/12 7:13 PM
Heat Pump or Electric Heat?? smorris1 Inspecting HVAC Systems 9 4/24/12 1:50 PM
Heat pump operation dmacy Inspecting HVAC Systems 2 1/2/10 4:51 PM
Radiant Ceiling Heat hhull Interior Inspections 9 7/26/07 9:19 AM
