Inspection for Seller. The seller’s son is an HVAC Contractor, and put this in a year and a half ago. It’s the vent for the High Efficiency furnace. He says it’s okay, and code. I say it may adhere to code, but will draw moisture into the condensing unit, and should be raised above it, or farther away.
yeah, but we don’t get the sideways rain here in WV!
I mean like the condensor sucking that fuel burning furnace vented air through the lower grills, and getting corrosion, both from moisture and whatever other contaminants may be spewing outta there!
I wouldn’t have written it up. The A/C will not be running when the furnace is operating so the exhaust or moisture cannot be sucked into the system even though moisture would not affect the A/C unit. However, if you still feel this is incorrect you can contact your local code office and send them your picture. If it does meet code, then fine and this will be confirmed for your clients in case another inspector writes it up when the house is sold. In the last 16 years, I have had to do this a couple of times to confirm if I was correct or not when I was in a disagreement with a contractor. Usually, they are happy to help, but I don’t know what they are like in your area.
lol, reminds me of when I was first married, our mobile home had no a/c, only electric furnace. I had a huge window unit in place. Many, many times I came home from work (in fall or spring), and there was a battle going on. Furnace on at night because it was chilly, then a/c on in the day when it was hot. By the time I got home from work, it would be a comfy 72 in the house, with both units going full blast!! I would cuss and rant at my poor wife who didn’t have a clue.
That said, mine tends to fall apart, even in the winter when it ain’t running.
I don’t think moisture damage has a “season”.
I certainly wouldn’t direct a moisture causing pipe right at the darn thing, even if it wasn’t running.
I just went through changing my venting on my high efficiency furnace and many manufacturers have very specific configurations for their venting. I’m not say it won’t work, just to verify.
Licensed Hvac contractor here. 25 years in the business. The out door unit and the furnace should not run at the same time. It should be fine. However I do see how if they did there would be reason for concern. If the furnace and the out door unit ran at the same time there would be a problem. Even if it were duel fuel. The evaporator coil always goes downstream of the heat exchanger. If the heat pump ran in heat at the same time as the furnace it would over heat the compressor. If the exchanger were downstream of the evaporator coil in the AC mode you would rot out the heat exchanger. I really don’t see where the exhaust from the furnace would cause any harm to the outdoor unit. Hope this helps.
