Old 10/30/09, 11:08 PM
Michael J. Merino's Avatar
Michael J. Merino Michael J. Merino is offline
Default HVAC Duct Issue
This is an inspection on a short sale house. The house has some moisture issues, with mold on the walls and carpet. The HVAC duct has this white substance on it. I am not sure if it was manufactured this way or if it is the result of the moisture. It seems to be consistent on all the visible duct work, but, some of the elbows are smooth and shiny with a little bit of the white on it.
HVAC Duct Issue-pa300045-jpg
Michael Merino
Merino's Home Inspection & Education Inc.
"Not just an Inspection, an Education"SM
Phone/Fax 708~535~6057
Find an InterNACHI certified North Carolina Home Inspector (and anywhere else in North America)
Old 10/30/09, 11:14 PM
Mark Nahrgang, C.R.I.'s Avatar
Mark Nahrgang, C.R.I. Mark Nahrgang, C.R.I. is offline
Default Re: HVAC Duct Issue
I'm not sure, but I think it's galvanized.
Mark Nahrgang
www.HeyMark.info
Old 10/30/09, 11:18 PM
That is what I am thinking, but the smooth shiny sections and the moisture issue has me wondering. I was not able to rub it off with my finger nail and it feels rough.
Michael Merino
Old 10/30/09, 11:22 PM
The smooth sections might be stainless...
The moisture wouldn't likely cause mold to grow on metal. Mold grows on organics, and if there was any dust on the ducts for it to grow on, you could wipe it off.
Mark Nahrgang
www.HeyMark.info
Old 10/30/09, 11:34 PM
Thanks Mark, you have been a great help.
Michael Merino
Old 10/31/09, 11:31 AM
James A. Levy's Avatar
James A. Levy James A. Levy is offline
Without a doubt Mike, that is in the galvanized plating. No worries mate!
Old 10/31/09, 1:50 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Do a ph test on the white stuff and check the sheetrock.
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 11/2/09, 7:02 PM
Brad G. Knowlton Brad G. Knowlton is offline
That is oxidized zinc from the galvanized sheet metal. This happens if they leave the sheet metal stacked with moisture between sheets before it is formed into ducts. I have refused many shipments of sheet metal for this very reason. It is only a cosmetic problem as far as I can tell, but many customers balk when they see it.
Old 11/2/09, 10:00 PM
Brian E. Kelly's Avatar
Great explanation. I did not know that.
"So, what are your thoughts on the Flir One??"
Old 11/6/09, 11:48 PM
Robert Sole, CMI's Avatar
Robert Sole, CMI Robert Sole, CMI is offline
Certified Master Inspector
In the steel industry we called it white rust. As was said, it is an oxidation of the zinc coating.
Robert Sole, CMI
407-637-7288
Florida license numbers HI 169 and MRSA 92
Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties.
RobertSole@REMinspections.com
Check out my blog orlandohomeinspections.info/
REMinspections.com
OrlandoHomeInspector.net
OviedoHomeInspector.net
Inspecting Furnaces. Please proof this new inspection article. gromicko Inspecting HVAC Systems 4 9/15/09 10:54 PM
What is your HVAC procedure? sstowe Inspecting HVAC Systems 66 5/28/09 1:48 PM
3 days left for HVAC discount bgromicko Miscellaneous Discussion for Inspectors 0 3/28/09 11:36 AM
Mold Remediation & Duck Cleaning Work-If Done Right dplummer Ancillary Inspection Services 8 10/12/07 3:03 PM
Strange Duct in Crawl Space jfunderburk Structural Inspections 3 1/11/06 1:02 AM
