Old 4/21/17, 3:09 AM
Bill Rich Bill Rich is online now
Default HVAC register in bedroom closet?
While inspecting a home today, I found a bedroom above a garage with no HVAC registers in the bedroom itself, but in the closet only? Is this an acceptable standard or is this a safety issue? What is your recommendation, and how would you report it?
BR Home Inspection Services LLC
Bill Rich
Canfield, Ohio 44406
330.550.4113
Bill@BRHomeInspector.com
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/21/17, 6:41 AM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
Default Re: HVAC register in bedroom closet?
No heating outlet in the bedroom . recommend correction each room is supposed to have heat . see them in a walk in all the time . why would it be safety issue ? Was it open frame in the garage area?
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Old 4/21/17, 10:33 AM
Thanks Wayne! Yes, I questioned the fact that it was in the closet and not in the room itself, and the garage area is not open, but finished. The safety part would be not getting enough air circulation along with heating/cooling in the bedroom when needed because the source was in the closet.
I did recommended the client seek a qualified HVAC contractor.
Bill Rich
330.550.4113
Old 4/22/17, 6:44 AM
Scott Frakes Scott Frakes is offline
Bill
Good job on recommending a heating contractor review.
Just as important, was there a return air in this bedroom or in the hall just outside?
Old 4/22/17, 11:34 AM
Erik Schmidt Erik Schmidt is offline
Pretty much a clue that the clueless participated in a reno, and that the inspector needs to look for more bonehead wiring, plumbing and HVAC.
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
Old 4/22/17, 12:03 PM
Scott,
Yes, there was a return vent in the room.
Bill Rich
330.550.4113
Old 4/27/17, 4:18 PM
Kris R. Beaudoin's Avatar
Kris R. Beaudoin Kris R. Beaudoin is offline
You are correct that each bedroom is supposed to have heat but it can be from a direct or indirect source, the source does not need to be in the room. If the heating is done indirectly (from a source outside of the room), the source that provides heat to the room in question must be able to maintain the minimum allowable temperature which is generally 68 degrees (some jurisdictions have amendments in their admin plan that allows for a different minimum temperature)
Kris R. Beaudoin
1059 Center Minot Hill Rd
Minot Me 04258
tel. 207-689-5482
Old 4/28/17, 8:07 AM
Joshua L. Frederick Joshua L. Frederick is online now
I'm assuming the closet has doors. Would you honestly think the room is going to be adequately conditioned with the doors closed? What would you say if this were in a home you were buying?
http://northwestohiohomeinspector.com
Defiance home inspector
Northwest Ohio home inspector
Old 4/28/17, 8:10 AM
What, like oxygen being circulated for breathing -lol? I still don't get what you're saying in regards to being a safety issue? Regardless, it's simply a matter of not heating or cooling/conditioning the room properly.
Old 4/28/17, 8:58 AM
Actually..... I have 3 bedrooms on my second floor heated by a heating source in a secondary room and nothing in any bedroom. Two of the bedrooms were part of an addition I built 3 years ago, Code had ZERO issue with it and I received the Certificate of occupancy without issue. I have no issue with the set-up and I live in Maine.
My point is that the OP is being told a heat source needs to be in a bedroom which is not true and he doesn't know one way or another if the system is adequate. I don't think its good advice to recommend an HVAC tech install heating components when they are 1. not required and 2. you are unsure if they are needed to maintain an adequate temperature. Just my opinion.
Kris R. Beaudoin
Minot Me 04258
tel. 207-689-5482
Old 4/28/17, 9:13 AM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Certified Master Inspector ®
I would report that it is good building practices to have a heat source in every room of the home (regardless of code).
On The Level Inspection
Gatineau, Québec
