Old 4/3/06, 3:01 PM
jford jford is offline
Default HVAC Salt Test
Whats all involved in a salt test? Is it more than a visual inspection of the heat exchange and CO test?
Old 4/3/06, 4:08 PM
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
Default Re: HVAC Salt Test
I believe a brine test is one type of test for determining if there are cracks in a certain shape/type heat exchanger.
Yes, it is more than a visual and more involved than using a CO meter.
Old 4/3/06, 4:53 PM
jrupert jrupert is offline
A salt spray test is a test for heat exchanger cracks, Its conducted by disconnecting the blower motor power wire so it will not run. The warm air plenum is opened for access. Water & salt mix is sprayed into the burners when on and a propane torch is passed over the area above the heat exchanger in the plenum, salt will pass through the crack and the blue propane flame will turn orange.
This can only be used on older 60% efficient or less furnace, it can not be used with any furnace that is a power Vented
John Rupert
Accurate Property Inspections
Solitaire Heating & Cooling
CSG Training (HVAC Training & Consulting)
Old 4/3/06, 11:50 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
sound way out of my scope.
Old 4/4/06, 7:32 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
The Gas Research Institute does not recommend or indorse the salt spray test because it causes corrosion. The methane/nitrogen mixture gas test is their approved method.
Old 4/8/06, 11:07 AM
This test was common 20+ years ago, it still can be used by an hvac company when they are pretty sure the furnace is cracked and will be changed out, I ran across a few hvac companys using this test this winter.
John Rupert
Old 4/8/06, 11:48 AM
Gary L. Porter's Avatar
Gary L. Porter Gary L. Porter is offline
Ditto Jay
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 4/8/06, 2:42 PM
rmyers1's Avatar
rmyers1 rmyers1 is offline
Please Note: rmyers1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Home Inspections are meant to be visual......period
There are many other ways of visually checking for cracked heat exchangers.
Suggest keep it visual, visual, and visual.
Old 4/9/06, 12:13 AM
Jay Moge's Avatar
i don't like the term "visual" for my inspections. i use tools, testers and what my clients call "gadgets" to perform a complete inspection. i do know what you mean, but i think we need a more betterer word for it. i call it "non invasive". i don't poke holes, take apart anything that isn't designed to be taken apart by anyone with more knowlage than me. if the homeowner is allowed to open an acces panel, so will i, we do go a bit further, but still within our scope, ie; panel covers, and accesses for the heat exchangers, etc, etc. these aren't to a level above "apprentice" and as inspectors, i think we are all qualified as apprentices in many feild pertaining to residential systems. access panels are meant to be removed without breaching the system itself. I'm not going to pull stems to check the wear on washers, but i will pull a filter for the furnace and see if it's dirty. looking at it is visual, but pulling it is the "more than visual" that i speek of. but we're on the same page. i'm just a little long winded tonite. (the hot arabic java flows much tonite....mmmmmmmmmmm)
Old 4/9/06, 12:20 AM
tneumann's Avatar
tneumann tneumann is offline
Add some Baileys to it..that will slow you down more to our speed..thank you.
Old 4/9/06, 12:32 AM
Jay Moge's Avatar
not a bad idea Tony, got any??? well now you all know the 3 sides of Jay. one is with coffee (usualy too much) one is with beer (again....to much) and the last one, well not quite as much fun, pretty boring realy. but that's when you don't hear from me so it doesn't matter.
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Test HVAC dmccauley Inspecting HVAC Systems 8 4/12/06 11:30 AM
HVAC Salt Test jford Legislation, Licensing, Ethics & Legal Issues for Inspectors 0 4/3/06 12:38 PM
