Old 11/20/09, 5:50 PM
David K. Lee David K. Lee is offline
Default hvac switch
Is it required to have a switch to turn off the HVAC unit or is it acceptable to be wired directly
Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America)
Old 11/20/09, 6:45 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
Default Re: hvac switch
For an indoor furnace there should be a switch between the furnace and the furnace room door. In in a basement, and not in a separate room, a switch should be between the basement steps and the furnace.
At exterior AC or Heat Pump there should be a disconnect within sight and readily accessible.
Old 11/21/09, 12:57 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
A switch, or any other means of disconnecting power from the equipment.
A plug in the wall fits the bill in your area. Common in condo's.
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 11/21/09, 1:10 AM
Bob Elliott's Avatar
Direct answer is yes there needs to be a switch.
Old 11/21/09, 11:08 AM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Please Note: bsmith is a non-member guest and is in no way affiliated with InterNACHI or its members.
A means of disconnect is required. Bear in mind that the means of disconnect can be a breaker, if the panel is in direct view of the equipment.
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing, Ethics & Legal Issues for Inspectors 52 7/11/17 4:34 PM
Flickering CFL jallingham Electrical Inspections 34 12/5/08 3:40 PM
HVAC Shutoff Switch jhagarty Inspecting HVAC Systems 3 11/22/07 1:35 PM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Home Inspectors 10 5/21/07 4:01 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 9:17 PM
