Old 4/24/07, 9:19 AM
Larry E. Freeze, TREC #8943 Larry E. Freeze, TREC #8943 is offline
Default HVAC in unvented, spray foam insulated attic?
Is there a verdict? pros and cons / effects
of unvented attic, sealed with Icynene spray foam
on HVAC system and ductwork?
[Plan is for 2-story construction, Central Texas
(read: outdoor temps around 100 F, humidity around 40%..) ]
Anybody with experience with such a setup
under these conditions?
How about considerations for "make up" air for HVAC system
for this?
Thanks!
Old 4/24/07, 10:25 AM
Charley L. Bottger's Avatar
Default Re: HVAC in unvented, spray foam insulated attic?
for this?
Thanks!
I would not be a fan of non-vented attics in Tx or Ok. due to moisture considerations. My thinking would be the ducts would have to be extra insulated to compensate for increased heat load.
Your use of the words make up air can be confusing, make up air is normally thought of as infiltration of normal use of external door use. Not to be confused with combustion air normally taken from an attic area. I would have concerns with combustion air on a totally sealed attic if truly sealed.
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
Okla State License # 130
580-268-3340
Old 4/24/07, 11:15 AM
Michael R. Boyett's Avatar
Retired Member
Larry...I inspected an icynene insulated house last summer just east of Pflugerville. I think it was around 4 years old or so and saw no issues with the ductwork in the attic. I'd have to go find the report and photos to refresh my memory but give me a call if you want some more information. Just visit my Homepage to get my number. Also see: http://nachi.org/forum/showthread.ph...hlight=icynene
Old 4/24/07, 11:41 AM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
https://www.nachi.org/forum/showthrea...unvented+attic
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Old 4/24/07, 12:00 PM
Cen Tex temps in sealed attics, insulated w/ spray foam...
Isocynene 'advertises' attic temps reach only about 80 degrees
instead of 130 degree range...
Have you found this to be somewhat accurate? such
a considerable reduction in attic temps in Cen Tex?
Old 4/24/07, 12:08 PM
We are moving toward spray foam insulated attics without ventilation in this area. I inspected one last week that was a few years old. The outside temperature was 80, and the temp in the attic was 76 in the mid afternoon sun. The attic I was in earlier in the day was well over 100 degrees with standard insulation and ventilation.
The utility bills on this home were also very low, comparatively.
I saw no issues in the attic or on the roof, however I understand that there is some concern that this type of insulation will cause a shorter service life on asphalt/fiberglass composition shingles.
Abraham Lincoln
Old 4/24/07, 12:28 PM
Roy D. Cooke, Sr's Avatar
I can not find it now but the article I read said there was not much difference in life and the Temp of shingles was only 5 degrees different .
. Sounds like a great way to go with all that I have read .
RoyCooke
Old 4/24/07, 12:51 PM
Bruce M. Graham's Avatar
When this first started there was a big concern with the shingles and warranty issuse, but there are several of the big roofing manuf. that warrant this type of contruction. http://www.jlconline.com/cgi-local/v...177f000001053f
Bungalows to Mansions
Professional Inspection Services, LLC
Bruce M. Graham III, CMI
Gainesville, FL 32608
352 871 8989
CERTIFIED MASTER INSPECTOR
Certified Level II Infrared Thermographer
NACHI05091592
ICC 5268478
www.BungalowstoMansions.com
Old 4/26/07, 10:40 PM
Banned
This method of insulating is being used in quite a few of the "Build America" homes with the HVAC unit/ducting in the attic. It's a big energy saver since any heating/cooling loss of conditioned air is essentially into the conditioned space of the attic and the ducting does not "see" the extremes of freezing winter and boiling summer temps. It also saves airsealing all the wiring and other penetrations of the ceiling.
This was brought into the program by a Canadian ex-R2000 engineer, Joe Lstiburek, the principal at Building Science Corporation ( www.buildingscience.com ) He has also worked with the American Lung Association on their "Health House" program as co-chair of the technical committee. Believe it or Not!!! A healthy new home is airtight and heavily insulated.
Old 4/26/07, 11:25 PM
Here is one from last year. Appeared to be working fine. I have some concerns about not being able to find a leaking roof until too late. Brought this concern to buyers attention, they were non-pulsed about it.
Old 4/26/07, 11:31 PM
and another
Old 4/28/07, 12:33 AM
Jimmy D. Breazeale Jimmy D. Breazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
I still have reservations about the life of roof coverings, but getting more convinced daily. One thing for sure: We'll all have to get better at spotting leaks in their early stages, before obvious damage takes place, since water would most likely be wicked into sheathing material. I'd like to hear others thoughts on this.
Old 4/28/07, 12:54 AM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
It can out-perform ventilated attics, but there does need to be some way for moisture to escape from the home to maintain indoor air quality because the home will be more tightly sealed when the underside of the roof is foamed.
Joe Lstiburek from the Building Science Corporation puts it a lot better than I can. His article doesn't have all the figures included yet but when it come to building science... HE'S THE MAN!
Kenton Shepard, CMI Inspector/Instructor
Director of Green Building
Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Old 4/28/07, 1:14 AM
Originally Posted by jbreazeale
I still have reservations about the life of roof coverings...
Venting the attic only cools the roof by about 5%. Light colored roof-covering material can cool it by about 25% and that's tops. (Building Science Corp. & DOE).
They recommend a low-permeability foam be used, so my question is more about the likelihood of roof sheathing decay if moisture gets trapped between the roof-covering material and the foam, especially if the roof membrane is also low-perm.
The one advantage I see to ventilated attics is that they allow the sheathing to dry to the attic side if the roof leaks.
Old 4/28/07, 4:20 AM
Todd Stromdahl's Avatar
Todd Stromdahl Todd Stromdahl is offline
My day job is working in the roofing industry at the manufacturing level, quality control lab. The issues about shortened life of roofing are not an issue do to the fact that the temperatures under the shingles (roof deck) are much lower than they would be in a vented attic. In Florida it's not uncommon to have temps of over 140 degrees in vented attics. The temps in the attic with rigid spray foam are similar to the temperatures in the rest of the house. As to the issue of make up air, some type of energy recovery system is needed (air to air heat exchanger) this will bring in fresh air and allow stale moist air out, without this it would be like placing your house in a plastic bag. Bad.
Foam spray roof ? jlybolt Roofing Inspections 35 11/17/17 4:26 PM
Question about exposed styrofoam insulation. mlong Exterior Inspections 11 10/30/16 11:50 PM
Foam spray roof ? jlybolt Exterior Inspections 0 10/22/07 12:30 PM
Spray Foam to the Rescue ? mcyr Structural Inspections 3 3/27/07 8:29 PM
