Old 10/28/08, 2:04 PM
Mark Nicholet's Avatar
Mark Nicholet Mark Nicholet is offline
Default Insulate both freon lines on heat pump?
Do you recommend insulating both freon lines on heat pump for when the flow is reversed in heating or cooling mode?
Insulate both freon lines on heat pump?-dsc06108-medium-jpg
Mark Nicholet
Apple Home Inspections
(250) 618-9127
InterNACHI member
Infrared-Certified
HIABC member
WETT Level 1 Certified
BC Licence # 65349
Old 10/28/08, 5:35 PM
Charley L. Bottger's Avatar
Default Re: Insulate both freon lines on heat pump?
Jeez you are just full of questions today We don't insulate both lines here and I don't recall every observing any MFG addressing that situation. Lets think about it a minute in the heat mode your liquid line flow is toward the outside unit hot gas traveling toward the inside unit. I saw your pic of the two lines inside one insulation tube. Heat always travels from hot to cold the liquid line will be much cooler than the hot gas line thus loosing some of its heat to the liquid line by simple contact which is intended for use within the A-coil. My simple deduction would be you want no contact between the two lines in heat or cool mode. That is my story and I am sticking to it.
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
Okla State License # 130
580-268-3340
Old 10/28/08, 6:58 PM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
It's not Freon, by the way. It's "refrigerant".
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Im curious as to why there are two liquid lines? Is there some kind of heat recovery system integrated into the heat pump, perhaps to augment the water heater? But in answer to the original question, no, Ive never seen or heard of anyone doing this either. The vapor line would be absorbing a lot of the heat from the liquid line which you do not want.
Old 10/28/08, 7:59 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
One is the thermostat wire.
As for insulating lines, the liquid line is always the liquid line in a HP.
It is never below the dew point so it does not need insulation. The reason for the insulation is to keep it from sweating, it has not real job in the thermal loss aspect.
The only time we insulate two lines is in refrigeration. The suction line is connected to the liquid line and is used to cool the liquid line to increase evaporator efficiency under load changes.
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 10/28/08, 8:39 PM
[quote=dedwards;430841]Im curious as to why there are two liquid lines? Is there some kind of heat recovery system integrated into the heat pump, perhaps to augment the water heater? But in answer to the original question, no, Ive never seen or heard of anyone doing this either. The vapor line would be absorbing a lot of the heat from the liquid line which you do not want.[/quote]
Doug only in the cool mode would that occure in the heat mode your large line or the hot gas vapor line would be the hottest of the two lines and you would not want any heat transfer from the large line to the small line as you want to transfer all of the heat possible at the A-coil not in the line set in between the two units. Yes Dave was right there is a thermostat wire in the pic that if one does not look close hard to tell.
Mister Funderburk Freon/Refrigerant is splitting hairs yes we know brand names
Yes David is right also, the liquid line is always the liquid line or the small line but it reverses flow and the vapor line or big line is always the vapor line either hot or cold but it also reverses flow depending on the Stat mode
580-268-3340
Old 10/29/08, 12:47 AM
David,
You are right, one is the thermostat wire and its the biggest one Ive ever seen. Looks just like copper until you look real close and see the swirl from the wire twisted inside the outer casing. Most of the ones I see are so wimpy, and typically dry rotted and hanging on a thread. This one is a lot cleaner install than most I run across.
Old 10/30/08, 1:46 AM
sparksnmore sparksnmore is offline
Please Note: sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like someone ran the stat wire inside 3/8" soft copper which I have done several time when the dog chewed the wires.
Of course I could be wrong, I was one time before.
Old 10/31/08, 10:38 AM
David OKeefe's Avatar
David OKeefe David OKeefe is online now
The liquid line seems to be kinked where it first turns up from the unit. Is this a problem? Would it restrict the flow?
Old 10/31/08, 10:59 AM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
I think they used the insulation as a protectection going through the wall is it insulated under the crawl space also?
Old 11/3/08, 12:40 AM
I think the kink is just camera perspective. was also looking at that.
A suction line kink is much worse than a liquid line kink.
It had better be!
BPI# 5015804
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing, Ethics & Legal Issues for Inspectors 52 7/11/17 4:34 PM
Radiant ceiling heat? bmargiotti Inspecting HVAC Systems 17 7/27/13 6:20 PM
Radiant Ceiling Heat hhull Interior Inspections 9 7/26/07 9:19 AM
Heat pump in a 80+ year old masonry house jskrypka Inspecting HVAC Systems 9 11/25/06 11:47 PM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 1:15 AM
