Old 7/6/13, 3:57 PM
Darren Taylor Darren Taylor is offline
Default Is this right?
I've been studying using the exam tool and came across the question and answer below. I thought efficiency was increased by pulling more heat out out of the combustion process which would DECREASE temperature of flue gas. Am I wrong?
Question: High-efficiency gas furnaces improve heating efficiency by _____
answer: increasing air flow and the temperature of flue-gas exhaust
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/6/13, 4:20 PM
David B. Fairbairn David B. Fairbairn is offline
InterNACHI Student
Please Note: dfairbairn is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Is this right?
You are correct. Very strange answer. Multiple choice? Trick question?
Old 7/6/13, 4:22 PM
Here is the whole question
High-efficiency gas furnaces improve heating efficiency by ______________.
increasing blower speed and evaporating flue gases
decreasing air flow and the temperature of flue-gas exhaust
reducing air flow across the heat exchanger
reducing the temperature rise and condensing flue gases
From Practice for State Licensing Exam (if your state requires it) - InterNACHI https://www.nachi.org/practice.htm?st...#ixzz2YILvRKxz
Old 7/7/13, 9:55 AM
Charley L. Bottger's Avatar
To me the above is the best answer of the group and it is poorly worded???????
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 7/7/13, 1:37 PM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Agreed Charley and something I am sure Ben would correct!
Old 7/8/13, 12:15 AM
Thanks guys.
Darren
