Old 1/21/14, 9:31 PM
Sean Fogarty's Avatar
Default Line set under slab
First for me today.
HVAC line set wet under ground and under the garage coming out the wall on the opposite side.
What issues are associated with this? loss of energy? premature rot?
Fogarty Inspection Services Group of Palm Bay FL
FL Licensed Home Inspector #8351
Infraspection Level 2 Thermographer #8788
FL Licensed Mold Assessor #MRSA2330
Certified Master Inspector
Home inspections, Commercial Inspections, Mold assessments, Thermal Imaging, Wind Mitigation and Insurance Inspections for Palm Bay, Melbourne, Cocoa, Titusville, Vero Beach and all the surrounding areas.
321-506-5125
fogartyinspectionservices@gmail.com
www.homeinspectorpalmbay.com
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/21/14, 10:30 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Default Re: Line set under slab
The biggest issue comes if the line-set ever needs replacing. If it's sleeved it's not that difficult. Absent a sleeve, the only real option is an exposed line-set - perhaps with a chase.
There are no "energy loss" issues (earth is an insulator) or "rot" issues (copper is allowed for direct burial) with underground sets.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/21/14, 10:46 PM
Thanks
321-506-5125
Old 1/21/14, 11:56 PM
Charley L. Bottger's Avatar
Not a big issue if the lines beneath the slab ever leak and they do quite often we just run a new set up the side wall in a chase to the attic. The lowballers never use a chase just exposed lines looks like crap
Never say never with energy loss here is a pic from today's inspect it is a split system heat pump 2005 look at the line set and tell me what would be in your report my Calif friend.
Line set under slab-dscf1611-jpg   Line set under slab-dscf1685-jpg
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
Okla State License # 130
580-268-3340
Old 1/22/14, 1:07 AM
Personally, I hate to see exposed lines. There's just no good reason not to use a chase, and your picture is a prime example of why - the insulation rots and reduces the overall efficiency of the system., especially if located on the "sunny side" of the home.
As for what I would report - I don't see any problem with the underground portion of the line-set, but the wall mounted section obviously should be re-insulated. In addition, I would recommend the insulation be protected from damage due to UV exposure.
What else am I missing?
P.S.
Out here in the big city, that unit is too close to the property line. I'm not sure if that's an issue out in the sticks
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/22/14, 8:18 AM
Personally, I hate to see exposed lines. Me too There's just no good reason not to use a chase, and your picture is a prime example of why - the insulation rots and reduces the overall efficiency of the system., especially if located on the "sunny side" of the home. it was on the sunny side of the home
As for what I would report - I don't see any problem with the underground portion of the line-set, This being a heat pump I do have a problem with it being under ground its loosing some heat to the soil and between that and the draw thru indoor coil and one single trunk supply duct in the attic I was having some serious air problems with this system. but the wall mounted section obviously should be re-insulated. In addition, I would recommend the insulation be protected from damage due to UV exposure. Agreed
What else am I missing? Ya did good for a city slicker
P.S.
Out here in the big city, that unit is too close to the property line. I'm not sure if that's an issue out in the sticks Not a problem in the sticks because it is not considered a permanent fixture it can be moved
580-268-3340
Old 1/22/14, 11:01 AM
I keep forgetting that you folks use heat pumps
Only a very small percentage of our systems are heat pumps. Gas-fired, forced air furnaces are so much more efficient and effective
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/22/14, 5:58 PM
No argument on that from me
580-268-3340
Old 1/22/14, 7:28 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
How about equipment pads, flashing and weep holes above grade? Insulate the pipes properly and have the HVAC serviced.
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
Old 1/23/14, 3:48 PM
Hey buddy what does weep holes and flashing have to do with a HP
580-268-3340
Old 1/23/14, 6:36 PM
Don't know, I thought since I don't know sh$t about HVAC to speak of, I point something out that I know.
Old 1/23/14, 9:29 PM
Sounds like your on the right track but if you sit still your bound to get run over.
I think Will Rogers said that
Come run with me I teach ya HVAC and you can teach me boards and ya may have to hit me with one
580-268-3340
Slope of waste drain line. mlong Plumbing Inspections 7 12/12/16 3:25 PM
1950's Slab Foundation? Mac A. Craig Structural Inspections 15 7/29/08 9:58 PM
Can sellers lie about a broken sewer line? gromicko Legislation, Licensing, Ethics & Legal Issues for Inspectors 1 7/15/08 12:18 PM
Slab Cracks common in 20 year old homes? Seth Williams Structural Inspections 16 5/6/07 6:47 AM
