Old 4/5/10, 11:21 PM
Sean Fogarty's Avatar
Default Look what I found today!
Thought I would never get to see one of these. 88 model. Had 2 mufflers on it, and worked flawlessly. I did let the buyers know about the recalls.
Look what I found today!-1-jpg   Look what I found today!-2-jpg
Fogarty Inspection Services Group of Palm Bay FL
FL Licensed Home Inspector #8351
Infraspection Level 2 Thermographer #8788
FL Licensed Mold Assessor #MRSA2330
Certified Master Inspector
Home inspections, Commercial Inspections, Mold assessments, Thermal Imaging, Wind Mitigation and Insurance Inspections for Palm Bay, Melbourne, Cocoa, Titusville, Vero Beach and all the surrounding areas.
321-506-5125
fogartyinspectionservices@gmail.com
www.homeinspectorpalmbay.com
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/5/10, 11:55 PM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
Default Re: Look what I found today!
And Sean Wins thata Boy award .
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Old 4/6/10, 12:51 AM
Keith Runquist Keith Runquist is offline
Send a message via AIM to krunquist
I see those all the time. Different parts of the country I guess. They have been a problem too many have been replaced due to me calling it out.
Keith Runquist, CMI
Old 4/6/10, 6:32 AM
Banned
Have seen 3 or 4 over the years way up here in Halifax,NS. Since we only have had natgas here in the last 7-8 years, they were burning propane.
Old 4/6/10, 10:22 AM
Greg Keene, CMI's Avatar
Greg Keene, CMI Greg Keene, CMI is offline
Certified Master Inspector ®
Sean - Found one yesterday in a crawl space - was unable to find a mod/ser # on it - Do you have info on the recalls?
Greg Keene
Clear Choice Home Inspections
Evergreen, CO
303-674-3234
greg@clearchoice-hi.com
Old 4/6/10, 10:37 AM
Jeffrey R. Jonas's Avatar
Greg, the recall that I am aware of, is from the mid to late 90's, and is expired.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 4/6/10, 10:41 AM
Lennox Industries, a major maker of high-efficiency home gas furnaces, has announced a factory-subsidized inspection program (recall) for Lennox Pulse furnaces installed between 1982 and 1989.
A company news release said unacceptable levels of corrosion had been found in some of the heat exchangers of furnaces manufactured and installed during that time. "A combination of things, such as condensation, impurities in fuel, inadequate cleaning or irregular inspections can, over the lifetime of the unit, lead to undetected corrosion of key components of the heating system", said Bob Schjerven, president and CEO of Lennox. "Improperly inspected or maintained furnaces can develop problems, including the possibility of carbon monoxide leaks that could be fatal," he added.
If you are unsure whether his or her furnace is covered by the program, he or she should remove the front door of the furnace and find the name tag. It will contain a number beginning with "GS14" or "GSR14", etc., followed by a series of other numbers and letters. One should then contact Lennox at (800)537-4341.
Old 4/6/10, 10:47 AM
Larry Kage, CMI Larry Kage, CMI is offline
No recall. Just a one time free inspection for the G14 only.
However Lennox does recommend that all G14's and G21's Pulse heat exchangers be inspected and pressure tested for leakage every 4 years. This inspection is the owners responsibility.
Also:
http://www.inspect-ny.com/heat/lennox1.htm
The company urges owners of Lennox Pulse furnaces installed between 1982 and 1989 to schedule a furnace and safety check with an independent Lennox dealer by calling 800-537-4341
[Try this newer Lennox Corporation contact telephone number: 900-622-8000, or
Try the contact links to Lennox dealers inserted by Google at the left side of this page - February 2007--DF].
The Lennox Pulse furnace safety inspection is free, but if the furnace has to be cleaned in order to be inspected, the customer could be charged for the cleaning.
To identify a Pulse furnace, look for its name on the door. If the unit is a Pulse 21 furnace, it was manufactured after 1990 and is not part of the inspection program.
For those with Lennox furnaces without the Pulse 21 name, the next step is to remove the front door and look for the name tag. These tags are usually placed on the inside cabinet wall on the left side of the furnace.
Locate the model number on the tag (either G14 or GSR14 followed by a series of numbers and letters) and the serial number on a tag below the name tag. Homeowners who caU the 800 number with the information will be told if their furnace is eligible for this inspection program.
The inspection program runs through July 1, 1999. If the warranted heat exchanger needs replacing, Lennox will provide a new heat exchanger at no cost to the owner. Labor costs for replacement parts are not part of the Pulse furnace warranty.
Awards Committee Member
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 4/6/10, 10:55 AM
Also:
Thanks Larry. That is what I was referring to in my other post above.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 4/6/10, 11:34 AM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
That is correct.
I had one last year and chased it down with a local HVAC contractor.
The unit was still functioning well.
They recommended annual heat exchanger testing.
I informed the client and recommended the installation of CO detectors. Done
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 4/6/10, 6:01 PM
Greg,
I think you have your info. Mine was an 88 model so it fell into that catagory. The recalls could have been done. Any furnace of that age I always recommend getting it serviced and inspected. Oh, and I did find a gas leak on the control valve. So much for not needing a gas detector huh??
321-506-5125
Old 4/6/10, 7:15 PM
Thanks guys - the buyer is a 70 yo widow and I want to help her all I can -
Greg Keene
Evergreen, CO
303-674-3234
I finally found some kweiss Thermal Imaging, Infrared Cameras & Energy Audits 6 10/12/08 4:50 PM
Update From Today pmagrone Legislation, Licensing, Ethics & Legal Issues for Inspectors 15 4/24/07 7:50 PM
Climbing up a ladder today kswift General Inspection Discussion 31 12/27/06 11:48 PM
