Old 6/12/17, 10:43 AM
Nick Gromicko, CMI's Avatar
Nick Gromicko, CMI Nick Gromicko, CMI is online now
Default New article: Inspecting Compression Cooling Systems.
https://www.nachi.org/inspecting-com...ng-systems.htm
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/12/17, 12:04 PM
Robert Tuscani Robert Tuscani is offline
Thumbs up Re: New article: Inspecting Compression Cooling Systems.
"An overly large system will blast on quickly, bringing the air temperature below the thermostat set point, and shutting off before it has had time to remove moisture from the air, which can cause moisture problems in the home, especially in humid climates"... Good advice - especially in Florida. Excellent read!
Old 6/13/17, 9:03 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Default Re: New article: Inspecting Compression Cooling Systems.
Also note this: which I ***** about on a weekly basis to those who like to test Delta-T with a thermometer!
AHRI uses a specific set of conditions (95° F outdoor, 80° F indoor, and 67° F wet bulb) when determining the equipment performance data, such as heating and cooling capacity,
If you can't measure wet bulb, you can't determine anything about performance.
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 6/16/17, 8:26 AM
Leonard Inkster, CMI's Avatar
Leonard Inkster, CMI Leonard Inkster, CMI is online now
Certified Master Inspector ®
Send a message via Skype™ to linkster
Nick it would be nice for us Northerners if you posted a map that included the climate zones of Canada. We have 3.
Future Proof Property Inspections Inc.
Leonard Inkster, CMI, CITP, CCHI, CPI, IAC2
Any information posted by me on this site should be considered a personal opinion.
Web: http://fppi.ca
Mail: leni@fppi.ca
"Every man always has handy a dozen glib little reasons why he is right not to sacrifice himself..." - Aleksandr Solzhenitsyn
