Old 4/16/18, 10:11 PM
Charley L. Bottger's Avatar
Default Radiant floor heat
I get the good ones!!!!!!! this was a 5K underground home we did a couple of years ago. There was a 22.5 KW electrical boiler trying to heat this structure. The building on its best day was unable to heat above 60 degrees. The heating tubes had improper spacing distance as per MFG specs and there was no barrier beneath the concrete floor allowing the temp to be absorbed into the soil.
Radiant floor heat-dscn2972-jpg   Radiant floor heat-dscn2982-jpg   Radiant floor heat-dscn2983-jpg   Radiant floor heat-ir_14669-jpg   Radiant floor heat-ir_14679-jpg
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/18/18, 9:10 AM
John Olson John Olson is online now
Default Re: Radiant floor heat
Charley, just curious, how did you determine there was no barrier beneath the concrete floor allowing the temp to be absorbed into the soil? thanks, John
Old 4/18/18, 4:38 PM
I didn't I was working with a PE doing the IR and HVAC work and the contractor ratted on himself to the PE. This home was in a law suite and has been settled out of court
580-268-3340
