Old 5/23/06, 11:04 AM
Gregory A. Liebig, CMI's Avatar
Gregory A. Liebig, CMI Gregory A. Liebig, CMI is offline
Certified Master Inspector ®
Question Rule of Thumb A/C sizing question from Practice Exam
I have a question regarding a question on the practice test. On page 11 there is a question that seems to conflict with the information I was looking up. The correct answer is 700 sq ft but some of the research I did supported 500 sq ft per ton. What is the correct answer? Wisconsin requires passing the National Exam and I’m doing everything I can to get ready for it within 2 weeks.
Greg Liebig
NACHI06051095
A rule of thumb for air conditioning is a ton of air conditioning is needed for:
  • 700 square ft
  • 500 square ft
  • A one story house
  • A hot day
References:
http://www.healthgoods.com/education/healthy_home_information/Space_Heating_and_Cooling/sizing_heat_and_ac.htm
The contractor asks you how many square feet of living space there are in your house. He (or she) then tells you what size unit you need. This is called "sizing by square footage" and is the most commonly used inaccurate method of sizing. A typical value used for air conditioners is one ton (12,000 Btu/hour) per 500 square feet (46 m2). This does not take into account differences among houses in design, construction, or energy efficiency.
http://www.uppco.com/business/eba_9.asp
Table 1: Capacity rules of thumb for room air conditioners
Rules of thumb for estimating air conditioner size vary by manufacturer. This example, from Carrier, includes the following suggestions for adjustments: If a room is heavily shaded, reduce capacity by 10 percent; if the room is very sunny, increase by 10 percent; and if using the unit in a kitchen, increase capacity by 4,000 Btu per hour.
Room area Capacity
(ft²) (Btu/h)
100 to 150 5,000
150 to 250 6,000
250 to 300 7,000
300 to 350 8,000
350 to 400 9,000
400 to 450 10,000
450 to 550 12,000
550 to 700 14,000
700 to 1,000 18,000
Source: Platts
Old 5/23/06, 12:17 PM
Ronald Dawes's Avatar
Ronald Dawes Ronald Dawes is offline
Please Note: rdawes is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Rule of Thumb A/C sizing question from Practice Exam
That's the rule-of-thumb we used for the Texas TREC exam. Of course, Texas is a bit warmer than some climates.
Old 5/23/06, 10:37 PM
jwilliams7 jwilliams7 is offline
I passed the National Exam about a month and a half ago, I used 500 sq feet/ton.
Old 5/23/06, 10:48 PM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Rules of thumb are dumb.
Using Air Conditioning Contractors of America (ACCA) Manual J heat loss/gain calculation method is more precise with less chance of oversizing equipment and reducing comfort.
Old 5/24/06, 12:14 AM
Joseph Burkeson, CMI's Avatar
Joseph Burkeson, CMI Joseph Burkeson, CMI is online now
You Betcha!
IRC - M1401.3 Sizing.
Heating and cooling equipment shall be sized based on building loads calculated in accordance with ACCA Manual J or other approved heating and cooling calculation methodologies.
Yes, I'd personally choose a CMI every time over every other inspector. ~ Nick Gromicko, InterNACHI Founder
Certified Master Inspector - 2010
Florida Licensed Home Inspector - HI176
Florida Licensed Mold Assessor - MRSA208
Square-One Inspection "Assurance begins here"
Old 5/24/06, 8:10 AM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Doesn't negate the fact that it's on the NHIE...
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 5/24/06, 8:33 PM
Rules of thumb may be dumb but if I inspect a house that's a ton undersized based on that rule and we are here in hot Texas then I will call for a HVAC guy to be consulted so he can do those calcs and tell the buyer if the AC is properly sized. I won't say it is not properly sized but I will say that it should be looked into.
Old 5/24/06, 10:56 PM
What Ronald said!
- Mike
NACHI05040682
(843) 442-9755
Old 5/25/06, 2:36 AM
I also agree that one should defer if they cannot give the client the best decsion. That still doesn't take away the facts of the question on the exam.
Old 5/25/06, 2:38 AM
Thanks Mike! That's my point exactly...
Sizing & Neutral Question? thejnicki Electrical Inspections 18 2/15/07 8:00 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
