Old 2/2/10, 6:50 PM
Andrew MacDonald's Avatar
Andrew MacDonald Andrew MacDonald is offline
Default Have not seen this before
From today's inspection. 2 story residence, built in 1997, both the Master bath and Hallway bath exhaust vent hoses terminate into the attic floor structure. As you can see, hose is foamed in place, the only exterior vent ports are the dryer and microwave. New one on me, can someone explain?
Thanks
Have not seen this before-bath-vent-003-jpg   Have not seen this before-bath-vent-004-jpg
Andrew MacDonald
MacDonaldPropertyInspections.com
InsightThermalDiagnostics.com
ITC/FLIR Certified Building Science Thermographer
ITC/FLIR Certified Level 1 Thermographer
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/2/10, 7:34 PM
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
Default Re: Have not seen this before
Check to see if it has a central fan unit down in the furnace room. Quite common in our area. Usually its piped in with solid tin ducting though? It typically vents out the side of the home down around the sill plate.
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 2/2/10, 7:35 PM
Banned
Thanks
The foam may have been for airsealing purposes or possibly just to hold the hose in place.(They don't use screws and brackets / metal strapping there??)
Of course, the bath fans must go to the exterior. (and not just out into the eaves with perforated soffit but fully to the exterior through a vent hood.)
Old 2/2/10, 8:44 PM
Larry J. Michael Larry J. Michael is offline
Should be to the exterior.
Jason Michael, CMI
Greensboro Home Inspection
Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas.
greensboro-home-inspection.html
Raleigh Home Inspection
Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas.
Raleigh-home-inspection.html
HomeSpectors.com
Providing home inspections in Greensboro, Raleigh, Winston Salem.
Old 2/2/10, 10:28 PM
I think you are missing my point. I realize the foam was there to hold the hose in place and to provide a barrier. I realize they need to be exhausted to the exterior. Can anyone explain the building principal of running the hoses into the interior cavity of the home with NO means of exit and how could this EVER be an acceptable practice. That is my point.
Andrew MacDonald
Old 2/2/10, 11:10 PM
Banned
Thought the flex duct was coming up from the wall and into the insulation on the attic floor.
Then Darrell's post #2 probably hit it right on....or were they planning on some central exhaust fan that never got installed?
Old 2/2/10, 11:25 PM
Joe Funderburk, CMI's Avatar
Certified Master Inspector
The duct is undoubtedly going to the soffit.
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Old 2/5/10, 3:01 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
I don't think it can be explained, because I don't believe it is an acceptable practice.
I would also be incline to believe that this was a "homeowner" installation, rather than part of the original build.
I would comment in the report that "the vent terminations were not visible and should be verified as venting to the exterior of the residence, or proper venting should be established by a qualified contractor."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/5/10, 3:05 PM
James E. Braun, CMI's Avatar
James E. Braun, CMI James E. Braun, CMI is online now
My guess is with Joe. Just turn on the fan and listen for it outside.
Old 2/8/10, 8:55 PM
William J. Decker's Avatar
Certified Master Inspector ®
Common around here. Stupid install. BTW: The bathroom exhaust pipe should be insulated.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 2/9/10, 6:06 PM
David C. Macy, CMI's Avatar
David C. Macy, CMI David C. Macy, CMI is online now
This is what I typically see that happens when you vent an exhaust fan out an soffit vent. The one pictured may have even missed the soffit opening.
There are a few problems that I see with installing out a soffit.
1) reduced insulation
2) Stained sheathing
It make more sense to vent towards a exhaust roof vent and not an intake roof vent like a soffit.
I do have an illustration that states it can be vented out a soffit. See attached
Have not seen this before-153910-022-jpg   Have not seen this before-bathroom_vent_wall_cap-jpg
Old 2/9/10, 8:51 PM
I disagree for this reason: anywhere you penetrate your roof, you are more likely to have a leak. Punching holes in my roof would not be an option. My personal preference would be to vent to a soffit using an approved soffit vent (there would be no stained sheathing in that case). The insulation loss is negligible.
Theodore Roosevelt
Ph: 704-351-1776
Old 2/9/10, 8:59 PM
Time for another Global Warming summit!
Theodore Roosevelt
Ph: 704-351-1776
Old 2/9/10, 9:07 PM
I did not say punch a hole in the roof, in most cause a vent opening is already there. I stated direct towards an exhaust roof vent like a ridge or roof top.
I disagree with your disagreement.
Old 2/9/10, 9:36 PM
Your illustration showed a dedicated roof bathroom vent. I misunderstood your position. Sorry.
Theodore Roosevelt
Ph: 704-351-1776
