Old 4/17/10, 6:26 PM
Richard D. Slocum's Avatar
Richard D. Slocum Richard D. Slocum is offline
Default Somethin is just not right !
OK , here is the weirdness of the day! 2001 Amana GFA furnace. Turn thermostat on, furnace kicks on, flame looks great , blower is quiet, everything seems to be working fine. So I walk around to check air flow from the vents and guess what? Heated air is coming from the cold air returns and the floor registers are sucking air back to the furnace ! These people have been living in this house for 9 years with the furnace working backwards!
Question: What would cause this?(I know it's not my job as an Inspector to determine cause, I just would like to know). Could the blower be wired wrong and running in reverse? This is the first time I've come across something like this.
Rick Slocum
NACHI # 04072697
Whitewood , SD 57793
ABSOLUTE Home Inspection Service
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/17/10, 6:32 PM
Jeffrey R. Jonas's Avatar
Default Re: Somethin is just not right !
Did you check the air flow at the filter to confirm it is a blower issue, and not a screwed up duct install?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 4/17/10, 6:45 PM
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
If you do what Jeff asked about, then you'll have a better idea what's going on.
Otherwise, it is hard to tell without more info.
Awards Committee Member
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 4/17/10, 6:55 PM
It is a Horizontal draft furnace in a crawl space. My original thought was that they have the duct work installed wrong(reversed)! But then I thought, how could they(HVAC contractor) screw that up and not notice it! Oh well , it's been called out and the HAVC guy can figure it out.
Thanks guys!
Rick Slocum
NACHI # 04072697
Old 4/17/10, 6:56 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
If they replaced the blower motor and wired it to run backwards, there will be little or no reversed air flow.
The motor direction can be reversed with two wires.
I'll put my money on the duct is switched.
Is this a packaged or split system?
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 4/17/10, 7:12 PM
Yeah , your right about the blower. The way the fins are configured there wouldn't be much air flow. It is a packaged system. I'm thinkin the ducts are switched. Thanks David !
Rick Slocum
NACHI # 04072697
Old 4/17/10, 7:37 PM
That is the first question we must ask when changing out a pkg hvac unit? What side is the supply?
If it is not on the same side: is there room for a transition?
BPI# 5015804
Somethin seems worng of missing? bkelly2 Interior Inspections 16 5/18/09 6:52 PM
