Old 5/5/18, 3:34 PM
Michael A. Senty Michael A. Senty is online now
Student Inspector
Default Water heater as boiler
Is there anything specific I should comment on using a power vent propane fired domestic hot water heater as a boiler? The system is isolated from the domestic water supply system. Domestic hot water comes from a different source. The heat system has a certain level (not totally adequate) of controls and safety, which I'm describing.
The main issue I'm looking for comments: Other than limited life span, lower boiler cost, water temperature, and BTU output; is there any specific issue I should point out? I've seen this type of system several times, this one being the best installation of the bunch.
Edit: Had a local propane expert look at the installation, and he said hot water heater as boiler is common in some areas. Some water heaters, this one included, are approved for use as a boiler. I don't know how to determine any future water heater as approved, but this is what I've learned.
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/6/18, 10:26 AM
Erik Schmidt Erik Schmidt is online now
Default Re: Water heater as boiler
Not a boiler, boilers make steam. It's still a water heater, and the system is a hot water heating, not steam heating. What your local expert told you is correct. Personally I would not comment on anything for a correctly installed system other than identifying it as a hot water heating system. Hot water systems can do things that forced air cannot, such as in floor heating and zoning, forced air can do things that hot water cannot, such as fast response to temperature change, ventilation and cooling, but once someone has chosen a system it is what it is.
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
Old 5/6/18, 10:41 AM
Charley L. Bottger's Avatar
Hey Erik how do you heat hot water Not all boilers make steam yes some just heat water and have a circulating pump for hot water. Just razzing you buddy.
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 5/7/18, 10:13 AM
When you boil you get steam, you will need steam control it's a capital investment...
Erik Schmidt
Edmonton Alberta
780 477 2666
