Old 10/28/18, 1:46 PM
Joshua LeBeau's Avatar
Joshua LeBeau Joshua LeBeau is online now
Question White powder on Vent Piping
Came across this at an inspection.
The galvanized vent pipe from the furnace has a white power on it.
My guess is the temperature of the furnace is too high. Natural Gas to the furnace was turned off.
Thanks for the help.
White powder on Vent Piping-2018-9-27-49-jpg
Joshua & Michelle LeBeau
www.HomeInspectionsbyJML.com
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/28/18, 1:56 PM
Jeffrey R. Jonas's Avatar
Default Re: White powder on Vent Piping
Lots of reasons, but for my area, it's typically due to high humidity, humidifier attached to furnace ductwork, stand-alone humidifiers in room, etc. Colder it gets, dryer it gets, (I'm in Minnesota) peoples crank up the humidifiers here from November until March... and then they usually forget to turn them down/off when out natural humidity kicks in (10,000 lakes and corn fields thing)!!
Jeffrey R. Jonas
Owatonna, Minnesota
Old 10/28/18, 1:58 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
This might help you here.
White Powder around Gas Vent - HVAC Forum - The Inspector's Journal
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
Old 10/28/18, 2:13 PM
Originally Posted by mcyr View Post
Good info, but, IMO... a different issue altogether.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 10/28/18, 2:38 PM
Well if it is, why don't you state what it is?
Old 10/28/18, 4:45 PM
I did.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 10/28/18, 6:31 PM
Well, like you said, it's an opinion.
Old 10/28/18, 8:09 PM
Well, mho, would be, white rust caused by oxidation from moisture.
Old 10/29/18, 11:19 AM
Russell G. Cloyd's Avatar
Russell G. Cloyd Russell G. Cloyd is offline
It is an indication of a flue gas leak which can be caused by a number of factors (improperly sized flue, open joints, improper termination, etc.) Defer to a licensed HVAC contractor.
Russell G. Cloyd
House 2 Home Inspections, LLC
859-739-7858
Certified Home Inspector
KY License #166164
Certified Radon Measurement Specialist
Certified IAC2 Mold Inspector
KY Fire Prevention Inspector
www.house2homeinspectionsllc.com
Old 10/29/18, 11:26 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
"White rust is a white powdery deposit formed from a natural corrosion process that can occur on any new zinc coated steel product. It is damaging to the appearance of the steel, not to mention to the anti-corrosion layer of zinc that protects the body of the steel."
http://www.orrconsteel.com.au/sites/...per-200531.pdf
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 10/29/18, 11:36 AM
Erik Schmidt Erik Schmidt is offline
Its all about how much and how long for. The white powder is oxidized zinc, the zinc is a sacrificial coating that protects the steel from corrosion (aka rust). Flue gases are hot and contain large amounts of water vapor, a product of combustion. Corrosion is a normal chemical process, chemical processes are accelerated with heat. When the zinc has been consumed the pipe will rust and need to be replaced. An excessive amount of white powder indicates that something may be wrong with the venting, a small amount is acceptable, especially if it is older installation. A mid efficiency furnace typically requires a smaller vent than a natural draft furnace, a too large vent could have condensation, which will result in more corrosion. Your call, if you think the amount of white powder is excessive, recommend a qualified HVAC or gas appliance tech to repair it.
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
