Old 1/30/10, 7:01 PM
Kenny Rigler Kenny Rigler is offline
Default White Substance On Ducts and Metal???
Hey Guys-
This was on a home built in the 70s with a half basement half crawlspace. The ductwork running through both were randomly covered in a white powder substance. It had a similar texture to joint compound or sheetrock mud. At first I thought maybe it got on the ducts when they were being made or stored, but I then noticed in the crawlspace that it was also on the metal plumber's tape, joist supports, and a little on the masonry blocks. The crawlspace had no ventilation and was completely dry. Any ideas what it might be from???
White Substance On Ducts and Metal???-img_2702-jpg   White Substance On Ducts and Metal???-img_2701-jpg   White Substance On Ducts and Metal???-img_2748-jpg   White Substance On Ducts and Metal???-img_2749-jpg   White Substance On Ducts and Metal???-img_2753-jpg
Rigler Home Inspections
Hays, KS 67601
785-656-0272
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/30/10, 7:17 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Default Re: White Substance On Ducts and Metal???
Search it.
This has been covered before...
Too much moisture is a place to start.
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 1/30/10, 11:05 PM
Found the post:
https://www.nachi.org/forum/f20/heati...t-issue-44671/
I should have looked harder before posting...thanks.
Hays, KS 67601
785-656-0272
Old 1/31/10, 12:25 AM
Bob Elliott's Avatar
Uncovered dirt crawl space is my first clue.
Old 1/31/10, 7:52 AM
Linas Dapkus, CMI's Avatar
Linas Dapkus, CMI Linas Dapkus, CMI is online now
Certified Master Inspector ®
The mortar joints appear to be efflorescence. I have seen asbestos duct wrap and removed this product in the past. The material is removed by wetting the material and scraping it of with a flat scraper. When done halfassed, residue remains. A closer look would be needed to determine if this is that product. If not, it's a moisture issue.
Linas Dapkus, CMI & LEO wannabe
Dapkus Home Inspections
Go away Rosie. You haven't had anything useful to say since you lost your mind when Trump won.
You are such a loser.
For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.
TRUMP/PENCE 2020
https://i.imgflip.com/1z058y.jpg
Old 2/1/10, 10:15 AM
Bob, could you explain further. First clue for what...moisture problems?
Hays, KS 67601
785-656-0272
Old 2/1/10, 10:18 AM
Linus, did you look at the forum link I posted above:
Originally Posted by bknowlton View Post
That is oxidized zinc from the galvanized sheet metal. This happens if they leave the sheet metal stacked with moisture between sheets before it is formed into ducts. I have refused many shipments of sheet metal for this very reason. It is only a cosmetic problem as far as I can tell, but many customers balk when they see it.
In that scenario it seems it was simply a moisture problem during storage of the sheets and only cosmetic problem. But it seems you're indicating it might be an asbestos residue issue. As I looked again at the previous post, they discussed not being able to scratch it off. Whereas when I tried it, it scratched off as a powdery substance. Which makes me think maybe it's more like what you're talking about. Did they still use asbestos wrapping in 1977? I know you only have pictures to work with, but do you have thoughts on which it might be?
Hays, KS 67601
785-656-0272
Old 2/1/10, 10:32 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Kenny, is that un-insulated duct work in the crawlspace?
Mid America Property Inspections, Inc.
Shawnee, KS 66216
www.mapii.com
NACHI # 05110992
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 2/1/10, 10:46 AM
Yes. Is there more to that question?
Hays, KS 67601
785-656-0272
Old 2/2/10, 9:36 AM
Kenny, there is an excellent training video on NACHITV, Advanced Inspection of Crawlspaces.
Thanks
Shawnee, KS 66216
www.mapii.com
NACHI # 05110992
Old 2/2/10, 9:50 AM
Insulation contractors installed their inventory of asbestos containing products until they ran out of it. I have been on hundreds of asbestos abatement projects where both products(ACM and Non ACM) were installed by the same contractor. They didn't throw out good insulation just because the government banned the use of it.
TRUMP/PENCE 2020
Old 2/2/10, 11:03 AM
Yep
No moisture barrier (condensation)
Old 2/2/10, 11:34 AM
Here are some more pics:
http://www.inspectapedia.com/aircond/DuctAsbestos.htm
http://images.google.com/images?hl=e...=&aqi=&start=0
TRUMP/PENCE 2020
Old 2/2/10, 7:43 PM
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
I agree to the moisture issue rather than asbestos...I havn't seen anything built in the 70's that still had ductwork coated with that stuff.
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 2/2/10, 7:48 PM
I worked in the asbestos abatement industry for 15 years beginning in 1987 and saw lots of it on ductwork.
TRUMP/PENCE 2020
Commercial Electrical Inspections jtedesco1 Commercial Inspections 29 1/12/08 6:03 AM
Asbestos ducts... Realtor accused me of trying to kill her deal... jwatts1 Inspecting HVAC Systems 19 7/20/06 12:44 PM
PVC conduit interior location kelliott Electrical Inspections 6 4/21/06 12:55 PM
