One of the Home Inspections turned out to be a Bank repo and what I found was the Air handler in the attic someone tried to tape the side panels with aluminum tape and it has come lose.
The only concern for the buyer was the out side condenser unit until I told him about the inside unit was pumping attic dust into the home and had very low air flow but he said it was cold. But as I told him the air flow was not up to stander for the air flow. As he said ya ya but it’s cold and that means it’s working right? An I told him No this will be a 3 to 4 Thousand repair cost.
**HVAC Systems replacement cost from HVAC rep do to age and condition of the system. I called HVAC sales tec and send some picture plus I am A/C cert.
Well see ya learn something everyday when the A-coil has been abused with dirt and lint some of us old guys just remove them and clean/replace instead of just replace:shock::shock:
Having the A-Coil removed, refrig recovered and all put back together will run you 4-600 around here. They will repair small defects on the coil, but won’t repair any defects in pan… period.
I would imagine the OP noted the muted airflow @ registers as the air is being lost at the deficient seal/seam between FAU and Coil… just a guess… whether it’s dirty or scope of work/cost should be left to the guy working on it.
4k is a bit steep… even for a condenser & coil, nvm properly sealing the defect that was noted.
Don’t have to recover the refrigerant from the system to remove the A-coil just needs to be pumped down and retained within the exterior condensing unit saves time and money
The InterNACHI membershall strive to improve the home inspection industry by sharinghis/her lessons and/or experiences for the benefit of all. This does not preclude the member from copyrighting or marketing*his/her expertise to other Inspectors or the public in any manner permitted by law.
The InterNACHI member shall assist the InterNACHI leadership in disseminating and publicizing the benefits of InterNACHI membership.
The InterNACHImembershall not engage in any act or practice that could be deemed damaging, seditious or destructive to InterNACHI, fellow InterNACHI members, InterNACHI employees, leadership or directors.* Accusations of a memberacting or deemed in violation of such rules shalltrigger a*review by the Ethics committee for possible sanctions and/or expulsion from InterNACHI.
The InterNACHI member shall abide by InterNACHI’s current membership requirements.
The InterNACHI member shall abide by InterNACHI’s current message board rules.
Members of other associations are welcome to join InterNACHI, but a requirement of membership is that InterNACHI must be given equal prominence intheir marketing materials(brochures and websites)compared toother associations of membership.
I see your point that is a marketing logo…I assumed by its name it was a home inspection organization. I assumed wrong and see your point. But the certified master inspector is a bunch of BS…but that’s the way it goes…
