Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 11/13/15, 4:52 PM
Christopher J. Goione Christopher J. Goione is offline
Default Crawlspace question.
I also posted this in the Emergency section, but was hoping someone could give me their feedback.
I did an inspection this morning in the Denver area, and the house had a crawlspace with a structural wood floor above it. The crawlspace was dry, with a humidistat controlled air exchange system (Which was not running based on the humidistat setting).
There was no obvious black mold like substances, but there was this white color (mold like substance?) on the bottom of some of the structural floor joists. Not exactly sure if it needs to be written up, and how it should be.
Thank you for any Advice
Chris
Crawlspace question.-20150311-sam_0533-jpg   Crawlspace question.-20150311-sam_0537-jpg   Crawlspace question.-20150311-sam_0540-jpg
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/13/15, 8:11 PM
James E. Braun, CMI's Avatar
Certified Master Inspector
Default Re: Crawlspace question.
Yes, it is mold. Usually happens on the bottom of floor joists due to moisture evaporating from the ground, such as no moisture barrier.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 11/13/15, 9:56 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
No insulation?
Stephen Stanczyk
RETIRED
Pierce County -Thurston County - King County - Kitsap County
Old 11/13/15, 10:05 PM
Jeffrey R. Jonas's Avatar
No vapor barrier?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 11/13/15, 10:16 PM
Thank you for the responses. Recommending further testing of white substance. And yes the vapor barrier , and insulation are noted.
Thanks Again.
Old 11/14/15, 9:46 AM
Rick Hiddemen's Avatar
Rick Hiddemen Rick Hiddemen is offline
When I see something like this i will usually check humidity areas in the area to verify my findings.
9 times out of 10 it is a gutter/downspout/grading problem.
Rick Hiddemen
Delaware Property Inspection
302 355- 1748
Wilmington De 19808
www.weseeit4u.com
Old 11/14/15, 10:13 AM
Joshua L. Frederick Joshua L. Frederick is online now
Hey Rick,
I have a few questions about your statement and if you can take the time to answer, I'd appreciate it as we're always learning.
How do you come to this conclusion? Are you saying if all this stuff you mentioned is ideal, there wouldn't be this white stuff on the bottom of the joists or high humidity wouldn't exist? Do gutter/downspout/grading problems cause moisture issues, including high humidity, in crawlspaces 9 out 10 times? If you fix this stuff at the exterior, will crawlspace moisture issues be solved...9 out of 10 times? If the crawlspace has functional/properly installed drain tile system, and walls are intact/moisture-proofed, will the gutter/downspout/grading systems make a huge difference, 9 out of 10 times? Do you tell clients what you stated when you run into moisture issues in crawlspaces?
Just trying to understand and stay educated, so I don't misinform clients.
Thanks in advance.
Old 11/18/15, 7:55 PM
Sharon D. Nicholson Pena Sharon D. Nicholson Pena is offline
Water?! is it in an area that was effected by the recent flooding? Recent as in w/I last few years.
Is the flooring new? Efflorescence. Some one correct me Please. These are my first thoughts on this pic and info alone. Next is how old is the house. Sometimes the truss and Beams for a house sit on ground for a while before the building and get wet and have discoloration. but the white on the steel beam too.....moldy looking.
Old 11/19/15, 2:27 AM
Roy D. Cooke, Sr's Avatar
http://unfccc.int/meetings/paris_nov...eting/8926.php
Old 11/19/15, 7:56 AM
Bob Rosinski, H101500084 Bob Rosinski, H101500084 is offline
I have a property that had the same mold. No moisture barrier,very similar pictures. It cost $1300 to clean,treat and install plastic on the ground. The end results were done very well. It has to remedied. No one will buy the property knowing this.
