Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 7/17/10, 12:20 AM
Dan Rubadue Dan Rubadue is offline
Default Garage Door w/no torsion spring???
Not sure if the units on the bar sides could be 'springs' but perhaps some of you have seen a setup similar to this, I have not (the garage door opener was not operating as designed)
Garage Door w/no torsion spring???-100_5441-jpg   Garage Door w/no torsion spring???-100_5440-jpg   Garage Door w/no torsion spring???-100_5442-jpg
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/17/10, 1:08 AM
Bobby Hamilton, CMI's Avatar
Bobby Hamilton, CMI Bobby Hamilton, CMI is offline
Certified Master Inspector ®
Default Re: Garage Door w/no torsion spring???
That's a Wayne Dalton Torquemaster system. Here's some info http://www.prodoorparts.com/articles...pring-systems/
Bobby Hamilton
Bloodhound Home Inspection Services
www.BloodhoundHomeInspections.com
Providing guaranteed home and termite inspections in the Akron, Canton, Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Old 7/17/10, 11:21 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
does the door remained open when detached from the automatic opener?
That's what you're supposed to be testing.
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 7/18/10, 9:26 AM
Bruce M. Graham's Avatar
I have that system at home, it is great and the opener mounts above the header
http://www.wayne-dalton.com/idrive_Torsion.asp
Bungalows to Mansions
Professional Inspection Services, LLC
Bruce M. Graham III, CMI
Gainesville, FL 32608
352 871 8989
CERTIFIED MASTER INSPECTOR
Certified Level II Infrared Thermographer
NACHI05091592
ICC 5268478
www.BungalowstoMansions.com
Old 7/18/10, 6:38 PM
Tim Spargo, CMI's Avatar
Tim Spargo, CMI Tim Spargo, CMI is offline
Balance of a garage door is important, that's for sure. I'm sure a lack of springs would indicate a poorly balanced door.
Tim Spargo
Spec Rite Inspections
Flir / Infrared Training Center Certified Thermographer # 66059
661-317-5770
Old 7/19/10, 8:55 AM
they also have some CE you can take
http://www.aecdaily.com/en/1448158?tabidx=1
352 871 8989
NACHI05091592
ICC 5268478
Garage door inspection procedure bgromicko General Inspection Discussion 8 9/17/17 4:21 PM
attached garage ghelder General Inspection Discussion 5 2/23/10 6:40 PM
Garage floor same level as house a safety concern? thorn2 General Inspection Discussion 11 1/25/10 4:33 PM
Attached Garage Fire Containment. Please proof this new inspection article. gromicko General Inspection Discussion 38 8/12/09 7:55 PM
American Home Inspection Service Area jmckenna1 Miscellaneous Discussion for Inspectors 3 9/4/06 8:23 PM
