Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 3/28/16, 6:04 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is online now
Certified Master Inspector ®
Send a message via ICQ to jkeilson
Default Lead Wate4 Testing Question
My question is in regards to the results and what to tell your client.
Is there some type of chart that shows acceptable (if any level actually is) of the levels of lead found in a drinking level lead test. Say 7.5 ppb (parts Per Billion, what to say?
Thanks in advance
Jim
"We Respect Our Clients Right To Privacy"
Jim Keilson Certified Master Inspector
MarylandHomeInspectionServices.com
www.MarylandRadonTesting.org
Specializing in All Air Quality
Mold and Radon Gas Testing
State of Maryland License# 31141
Virginia License#3380 000468
InterNACHI ID: NACHI10101807
(IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors, Also servicing All of Northern Virginia and Washington, D.C.
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/28/16, 6:08 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Default Re: Lead Wate4 Testing Question
Have it tested..Yep!
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Old 3/28/16, 6:11 PM
hanks Roy, short and to the point..LOL.
Do you know what type of contractor (or whomever) does this type of work ?
Would it be a plumber ?
Jim
