Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Ancillary Inspection Services
Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 6/20/14, 1:39 PM
David Nasser's Avatar
David Nasser David Nasser is online now
Default Main Electrical Panel says: Radon fan in the crawlspace..need help
Home was built in 1927, southern calif.
Raised foundation - crawlspace
Home looks good and has been maintained.
Main panel says: Radon fan in crawlspace.
I got pic of some type of device in the crawlspace...
Is this device a Radon fan?
What is the write up..for a situation like this?
David
An Ounce of prevention is better
than a pound of cure :}
www.pyramid-home-inspections.net
Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/20/14, 2:28 PM
Blake T. Spann, CMI's Avatar
Blake T. Spann, CMI Blake T. Spann, CMI is offline
Certified Master Inspector
Default Re: Main Electrical Panel says: Radon fan in the crawlspace..need help
Its hard to see details from that one picture but it looks like a handyman's attempt to install a radon mitigation system. I'd try to find out who installed it, and when? Any information you can get. Big thing I noticed it is missing the vapor barrier which is a very important part of a crawlspace mitigation system. Personally, I think I would recommend a retest(because obviously it had high radon prior to the install) and the reason being is because: there appears to be a Radon "like" mitigation system present, however the system appears to be "handyman" installed which brings into question the functionality of the system itself. If the test results still come back acceptable it is up to them if they want to leave it that way or have a proper mitigation system installed, but I'd still call it out either way.
844-Inspekt
www.HOMEINSPEKT.com
Old 6/20/14, 2:31 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Don't wast time playing investigator.
It's old.
It's not right.
When was the last time the house was tested for Radon levels?
Write up what you see and move on.
As a Professional Home Inspector, I support the privacy of my clients.
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 6/20/14, 2:49 PM
It's old.
It's not right.
Yes, I agree... at this point I wouldn't waste time trying to investigate, I was speaking in terms if you were still onsite. If I see something like this, the first thing I do(if the seller is present) is try and find out some information on it. Takes only a few minutes.
844-Inspekt
www.HOMEINSPEKT.com
Old 6/20/14, 7:00 PM
Thanks everyone....this gives me enough info to write it up.
ESA Mold Inspector course jszczesny IAC2 Indoor Air Forum 42 1/25/13 10:12 PM
Word count of our inspection narratives as of today tops 300,000 words. Wow. gromicko Miscellaneous Discussion for Inspectors 47 12/21/12 8:09 PM
Florida Radon wchandler Florida Home Inspectors 61 3/7/12 10:27 AM
Electric Panel dmozzillo Electrical Inspections 26 1/26/09 1:18 PM
