Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 1/21/13, 6:33 PM
Gary Young Gary Young is offline
Default Pool inspection and strainer pot
Just made a home inspection with pool and run in to an unusual situation that hasn't happened before. The pool pump was continuously running and water was circulating through the jets. What seemed unusual to me was the strainer pot never had water going through it. I've always saw water circulating through the strainer pot attached to the pump. Why would no water be circulating through the strainer pot.
Their was a solar energy system which was circulating.
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/21/13, 7:50 PM
Mike Hazelwood's Avatar
Mike Hazelwood Mike Hazelwood is online now
Was there an automatic vacuum? If so the valve may have been set to pull from the vacuum and not the skimmer.
Mike Hazelwood
Bakersfield, California
calpro@calproinspections.com
www.calproinspections.com
Old 1/21/13, 7:55 PM
Robert Ernst Robert Ernst is offline
Default Re: Pool inspection and strainer pot
I think it was just a valve setting. I've have seen lines marked as VAC for the skimmer also. Were any of the lines marked? They should be if they are not.
Nevada Inspector of Structures #1730
Nevada Energy Auditor #30
www.homecsi.com
Old 1/21/13, 8:37 PM
Joseph Hagarty, CMI's Avatar
Joseph Hagarty, CMI Joseph Hagarty, CMI is offline
Certified Master Inspector ®
more than one pump?
picture?
Joe Hagarty
mrdryervent@gmail.com
Cell: (484) 883-7018
Boulder, Colorado
Certified CMI Master Inspector Instructor
PA NACHI Certified Inspector # 01102902
PA Licensed Radon Inspector # 2080
PA Licensed Pesticide Applicator # 700884
Delaware Licensed Home Inspector # H4-071
Old 1/21/13, 9:04 PM
No auto vacumn. There was a valve set midway btwn the fountain and the drain.
Old 1/21/13, 11:10 PM
Unless the fountain sucks water the two wouldn't be on the same valve.
www.homecsi.com
Old 1/22/13, 2:02 AM
Even when missing an auto vacuum and hose, the insert it attaches to could be wide open. Was there a valve just before the pump inlet?
Mike Hazelwood
Old 1/22/13, 9:07 AM
Dominic DAgostino, HI3957 Dominic DAgostino, HI3957 is offline
Gary,
I'm confused. You stated no water in the strainer pot; are you describing the pool's skimmer or the pump's strainer basket, perhaps with a clear lid?
It's impossible to not have water in the strainer pot/ basket if water is flowing into any part of the pool, as it must move through the pump.
Old 1/22/13, 9:44 AM
John Ritter John Ritter is offline
Please Note: jritter is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just a thought, if the pump and filter system is on a timer and the heat system is manual, then heat could be energized by closing a valve and starting pump and forgetting to turn timer off for filter system Pump came on after and sucked water out of strainer.If there is no air bubbles in pump strainer sometimes it is hard to see the water in it. The other thing is, did one pump sound a lot louder than the other or were they both the same?
Old 1/22/13, 6:44 PM
Thanks guys, it appears the strainer pot had so little air that it looked like there was no water in it. No problem.
