Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 1/1/16, 1:08 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
Certified Master Inspector
Default Pool temperature control
The air temp here is a pretty constant 72F. The pool here is about 70 F and I'd like to turn it up about 5 degrees. The pool guy says he can't. I don't believe it. There's got to be a mixing valve somewhere. There's no control in the underground mechanical room that I can recognize as maybe controlling water temp.
This is the only control I can see without climbing onto the roof, and I don't have access permission. Does this look like a thermostatic control for water temp?
Pool temperature control-panels-1-jpg   Pool temperature control-panels-2-jpg   Pool temperature control-panels-3-jpg   Pool temperature control-panels-4-png
Kenton Shepard, CMI Inspector/Instructor
Director of Green Building
Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/1/16, 1:18 PM
Default Re: Pool temperature control
The mechanical room. Pump not grounded that I can see. This thing going to kill me?
Pool temperature control-mechanical-1-jpg   Pool temperature control-mechanical-2-jpg   Pool temperature control-mechanical-3-jpg   Pool temperature control-mechanical-4-jpg   Pool temperature control-mechanical-5-jpg
Old 1/1/16, 3:11 PM
Ian W. Mayer, CMI's Avatar
Ian W. Mayer, CMI Ian W. Mayer, CMI is online now
Certified Master Inspector ®
On a gas heater, it's pretty simple. On a solar heater as pictured, you, of course, are limited by what the sun does. But that said, solar heaters can be pretty effective when they're not leaking (and prone to leaks appears their biggest draw back). Most pool heaters I see are gas, and the few solar heaters I've seen didn't have an actual temperature control thermostat.
Pool pumps don't have to be grounded per se at the pump itself, they have to be bonded.
The electrical system as a whole should be grounded, and that fuse box looks pretty scary.
It looks like a shock hazard from here.
Old 1/1/16, 3:28 PM
There's no grounding or bonding of any electrical components on this property, or on most properties in Mexico.
Old 1/1/16, 8:27 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
...that fuse box looks pretty scary.
Are those wires soldered to the outside if the main cartrige fuses?
Pool temperature control-1-jpg
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 1/1/16, 10:33 PM
Chuck Evans's Avatar
Attachment 115274
Probably just wedged between the fuse clip and the fuse.
Kenton, always let someone else enter the pool before you and don't touch the railing.
Chuck Evans (TREC #7657)
The Woodlands Home Inspection
Houston, TX
Awards Committee Member
Old 1/1/16, 11:30 PM
YAH, I have never seen wires placed across fuses like that. I don't know what it means. Mexican electrical is very unique.
For the first month here I could never figure out where the neutral conductor was coming off the pole. All I saw was the phase conductor. Finally I realized that the neutral and phase (hot) conductors were housed within the same conductor insulation. They appeared to be one wire coming off the pole.
Just inside my front door I have a dirt space where squirrels have tunneled in and now I look up from writing sometimes and see squirrels running across my floor. I would like to test my pool each time before swimming by tossing a squirrel in, but I can't seem to catch one.
Old 1/2/16, 8:33 AM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
It means there is no fuse.
Same as the old penny under a buss fuse trick. NO protection whatsoever.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 1/2/16, 9:29 AM
Michael A. Clark, CMI's Avatar
Michael A. Clark, CMI Michael A. Clark, CMI is offline
This isn't totally accurate. The protection IS the wire.
In the absence of a fuse, when the wire melts in two, the circuit becomes open!
Michael A Clark, Certified Master Inspector®
Inspection Connection
St Albans, West Virginia
"Always tell the truth,
do what you say you will,
and do it Righter than Right...Always"
Facebook
Google Plus
www.charleston-home-inspector.com
www.icwvhomes.com
mclark@icwvhomes.com
Old 1/2/16, 9:31 AM
And what is the clearing capability of of said wire?
Michael Larson
Hudson, WI
Call me
Old 1/3/16, 1:00 PM
James E. Braun, CMI's Avatar
James E. Braun, CMI James E. Braun, CMI is online now
I love fried squirrel!
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 1/3/16, 8:04 PM
Is using a squirrel as an electrical testing device an accepted ASTM inspection method?
I think it is in México. Association of Squirrel Testing Methods (ASTM)
Old 1/3/16, 8:11 PM
I agree. I'm not going back into the pool until I ground the pump and replace the breaker with a GFCI type. If the fuses were bypassed because they kept blowing, that indicates to me that there's possibly some other electrical problem, although I'm guessing that the fuses were the original. OCPD and once the breaker was installed, they decided to bypass them with the wire.
Old 1/3/16, 8:32 PM
...and, as far as the temperature control, there should be something that's basically a TPR valve for water running through the tubes in the panel, and that valve would be set to open at a pre-determined temperature. And then there's be a mixing valve that controls the temperature of water entering the pool. This is pretty obviously a thermostat calibrated from 30 F to 110 F, so I don't see what else it could possibly control.
