Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 11/1/17, 3:31 PM
Brett Huckabee Brett Huckabee is offline
Default Radon Level of ZERO?
OK so I recently did a test of a new build that had a passive system but the levels came back at around 10 pCi/l. They installed an active system and I conducted a 96 hour re-test. The re-test came back at 0 pCi/l! I've never had a zero reading before and didn't even think it was possible. The highest recorded was 0.3 with many 0.0 readings (96 hour test). This was conducted with a recently calibrated RS800 with closed house conditions but I'm a little concerned that either my machine fouled up or they had the windows opened or something. No tamper or weird temp or humidity was recorded. Any suggestions?
Of course they're anxiously awaiting my results as it's the last thing for the deal...
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/1/17, 5:26 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Default Re: Radon Level of ZERO?
Background is above zero
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 11/1/17, 5:35 PM
John Olson John Olson is online now
The radon rate drops a lot when a system is installed. Don't second guess the 2nd readings if you didn't 2nd guess the first. Trust your equipment.
Old 11/2/17, 7:09 AM
Thanks I was just in a bit of a panic with a very particular buyer and I've never had my equipment read so low. I'm running a side by side comparison right now to make sure my machine didn't crap out. I noticed the readings that were really low (i.e. 0.03 pCi/l) were thrown out by the system and recorded as 0. Anyway, client was cool with it and I even offered a re-test for confidence. I'll post if anything weird shows up.
Thanks for your input.
Old 11/5/17, 10:58 AM
Mike Pagozalski, CMI Mike Pagozalski, CMI is offline
What's the margin of error for the machine? I don't do radon mitigation but I do own a house that has it lol, and I test for it often and I would be surprised to see it go from a 10 to none or below 1 unless they went overkill on the system
Mike Pagozalski
Mike@InspectTally.com
850-528-5585 (Cell)
FL Certified Home Inspector HI9519
FL Licensed Real Estate Broker BK3055789
FL Radon Measurement Technician R2530
ITC Level II Thermographer #150761
Exterior Design Institute (EIFS/Stucco) #FL131
Tallahasee's Home Inspection Team
Tallahassee Radon Testing
Tallahassee Home Inspector
Old 11/5/17, 11:19 AM
Jeffrey R. Jonas's Avatar
Have you ever performed a "Long Term" test?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 11/5/17, 11:25 PM
As in more than 90 days, no.....
Mike Pagozalski
850-528-5585 (Cell)
Old 11/6/17, 8:45 AM
The fact that you "test for it often" infers that your climatic conditions change often enough to effect you readings. Run a 9-12 month longterm test to get a true reading of your homes environment. Use that reading as the basis for what you need to do next.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 11/9/17, 8:36 AM
BTW I did an additional comparison test with 2 machines simultaneously and they were within 0.3 pCi/l of each other so I think they're good to go. I learned the radon mitigation fellow put in a larger fan size and that may have contributed to this very low reading. I did recommend a Sentry Siren and long term testing.
Old 11/10/17, 8:39 PM
I "tested for it often" ( I meant in general, but I did my home as well) just to build some experience with how tests can be influenced by all the above.....sadly my house was a perfect testing ground to learn on lol, but a long term test wasn't going to happen because mitigation was planned on day 3 lol.....I agree that a true long term test would have given the best info but we weren't going to wait ( especially when 3 weeks after the first test we found out we were expecting ( which turned into twins who showed up 10/20/17))
Mike Pagozalski
850-528-5585 (Cell)
