Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 5/9/16, 12:49 PM
David OKeefe's Avatar
David OKeefe David OKeefe is offline
Default Radon mitigation pipe stainiing
Radon mitigation system installed in home today. I noted staining on the PVC pipe in the basement but only in the basement piping and not on the whole pipe and not anywhere else. Any ideas? Is this mold? and why would it be on the pipe only? Could it of been on the pipe during installation? System put in about 6 years ago.
Radon mitigation pipe stainiing-dscn0411-jpg   Radon mitigation pipe stainiing-dscn0418-jpg   Radon mitigation pipe stainiing-dscn0419-jpg   Radon mitigation pipe stainiing-dscn0467-jpg
David
InterNACHI Certified Home Inspector #08051301
NYS Licensed Home Inspector #16000038229
NYS DEC Certified Pest Technician # T4865884
518-505-8305
HouseAbout Home Inspections, LLC
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Connect on LinkedIn
Follow HouseAbout_LinkedIn
Follow me on Twitter
HouseAbout_Instagram
Google+
Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/9/16, 1:57 PM
Ian M. Robertson Ian M. Robertson is online now
Default Re: Radon mitigation pipe stainiing
Condensation making moisture from the temperature differential (a radon pipe in the basement area is usually cooler because it is pulling out ground temperature air). As for mold, most likely - but not sure. I see it a lot on radon pipes and well pipes
Ian M. Robertson, CMI
www.spec-pro-inspect.com
Old 5/9/16, 2:44 PM
Thanks Ian, Most of the staining was where the pipe exited the slab and ran about 12-15 feet before it dissipated. Possibly the the air warmed upped as it was drawn through the pipe? I don't think this is a situation where I need to call for an assessor.
David
518-505-8305
Connect on LinkedIn
Google+
Old 5/9/16, 3:08 PM
Yep, that is typical. Usually by the time the pipe hits the first floor the air is warmed up. As for an assessor, anything over 10 sq ft according to the law, so use your judgement.
Old 5/9/16, 3:27 PM
Jeffrey R. Jonas's Avatar
Originally Posted by irobertson View Post
....As for an assessor, anything over 10 sq ft according to the law, so use your judgement.
Consider this... a 10 ft section of pipe with a circumference of 12 inches would be the limit... BUT... all of the white space surrounding the (suspected) mold spores is not (suspected) mold, so subtract the white space from the total and you are good to go!
Jeffrey R. Jonas
Owatonna, Minnesota
