Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 3/25/16, 1:59 PM
Anthony E. Tilidetzke Anthony E. Tilidetzke is offline
Certified Master Inspector
Default Radon test procedure- canisters
When taking a Radon test the EPA says, keep the canisters or device above floor 20 inches minimum. This test is on the main I beam in the basement, thoughts? I just found EPA procedure says:
The detector should be at least 50 centimeters (20 inches) from the floor, and at least 10
centimeters (four inches) from other objects. For those detectors that may be suspended, an
optimal height is in the general breathing zone, such as two to 2.5 meters (about six to eight
feet) from the floor.
Radon test procedure- canisters-img_3201-jpg
Anthony Tilidetzke
VIP Inspections LLC
VIPinspector.com
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/25/16, 4:50 PM
Jeffrey R. Jonas's Avatar
Default Re: Radon test procedure- canisters
What did your training instruct you to do?
What does the manufacturer of the canisters instruct you to do?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 3/25/16, 5:25 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is online now
Certified Master Inspector ®
Send a message via ICQ to jkeilson
BINGO !!!!
Jim
"We Respect Our Clients Right To Privacy"
Jim Keilson Certified Master Inspector
MarylandHomeInspectionServices.com
www.MarylandRadonTesting.org
Specializing in All Air Quality
Mold and Radon Gas Testing
State of Maryland License# 31141
Virginia License#3380 000468
InterNACHI ID: NACHI10101807
(IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors, Also servicing All of Northern Virginia and Washington, D.C.
Old 3/25/16, 6:21 PM
That picture is not my test, never heard of this company before. They have no instructions on the web site and closed for good friday.
http://www.radiationdata.com/
Just seemed odd to me that the inspector placed them on the I-beam in the laundry area.
After reading the EPA guidelines apparently 6-8 feet is perfectly normal, although I did also read the EPA says one high reading doesn't mean mitigation, they recommend another test!
This was placed in a home I am selling, I placed my Radstar in the basement rec. room and we will see how accurate the canister's are compared to the radstar, I could not place my tester where he put his so it is fairly close, start time was almost exactly the same. I'll update the results for any curious individuals.
Anthony Tilidetzke
VIP Inspections LLC
VIPinspector.com
Old 3/25/16, 6:45 PM
David OKeefe's Avatar
David OKeefe David OKeefe is online now
I would not put my test canisters on the I beam or in the laundry area. The basement rec room is the spot to put them in (living area of basement). I bring my own test stands so that I can place them in the same spot (height) every time.
Radon test procedure- canisters-dscn6161-jpg
David
InterNACHI Certified Home Inspector #08051301
NYS Licensed Home Inspector #16000038229
NYS DEC Certified Pest Technician # T4865884
518-505-8305
HouseAbout Home Inspections, LLC
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Connect on LinkedIn
Follow HouseAbout_LinkedIn
Follow me on Twitter
HouseAbout_Instagram
Google+
Old 3/29/16, 9:05 PM
Results came back today- The charcoal canisters were 2.4 and 2.5, my radstar 300 was 2.5 . Unreal how close the results were. The charcoal canisters were hidden up on an I-beam and registered the same as my tester 10 feet away at 30 inches off the floor.
Anthony Tilidetzke
VIP Inspections LLC
VIPinspector.com
Old 4/3/16, 1:01 PM
Stephen H. Payson's Avatar
Stephen H. Payson Stephen H. Payson is offline
Originally Posted by atilidetzke View Post
.....never heard of this company before.
Radiation Data is a radon testing laboratory and canister supplier out of Skillman, NJ. It's the lab I'm affiliated with (required for licensing in NJ). They would have nothing to do with the canister placements.
Stephen H. Payson
Peak Inspection Services
Office: 908-750-6789
NJ Home Inspection License #24GI00125400
NJ Radon Mesurment Technician License #MET13261
InterNACHI# 13081415
www.peakinspectionservices.com
steve@peakinspectionservices.com
Residential Inspections | Commercial Inspections
Serving all of Northern New Jersey
Over 34 Years of Contractor Experience!
Old 4/3/16, 5:43 PM
Do they (radiationdata) advise on proper testing procedures or do they follow the EPA recommendations? How much do the tests costs? I would like to have some spares tests for when my Radstar is in use.
Anthony Tilidetzke
VIP Inspections LLC
VIPinspector.com
Old 4/3/16, 7:58 PM
Why do you think there is any difference between the two?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 4/13/16, 1:45 AM
John A. Reim's Avatar
John A. Reim John A. Reim is offline
In Illinois they must be 20 inches to 6 feet from the floor. Most I beams would be over 6 feet, and violate the 4" away from other object rule. We also do not test in kitchens, laundry rooms or bathrooms due to humidity.
