Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 10/12/17, 7:30 PM
Zach C. DeAugustine Zach C. DeAugustine is offline
Arrow Radstar Electronic Continuous Monitor (radon)
okay, so with an e-perm or charcoal tests, you're supposed to have 2 canisters roughly 6 inches or so apart. This would be a 48 hour test. Now with above type of monitor, do i need to run it for 96 hours and check it at the 48 hr mark? or will that be okay at the 48 hr mark since it measures every hour.
Also, if i get the results on the spot and write the report, will that be considered a lab, technically?
Maryland and Pennsylvania
Old 10/15/17, 10:47 AM
Steve Nadeau's Avatar
Steve Nadeau Steve Nadeau is online now
Default Re: Radstar Electronic Continuous Monitor (radon)
If you are using a radstar or similar ECM, you just run one 48 hour test IF the home has been in a "closed" condition for 12 hours before the test.
No, I don't believe your ECM is a lab.
Right now I'm getting a "Error reading COM 4" message while trying to download my RS300 and I'm spitting nails trying to figure that one out - I don't have their printer.
