Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 5/5/15, 10:39 PM
Manny Marinos, CMI's Avatar
Manny Marinos, CMI Manny Marinos, CMI is online now
Default Reporting WDO
Tonight I inspected a 55 year old home that was previously treated as per the drill holes throughout the entire unfinished basement. I did find 2-3 small, old mud tubes on a joist with no damage. How would you write it up on the NPMA-33? Would you recommend a treatment being it was already treated?
Homeguard Home Inspection
Serving all of Nassau and Suffolk County
Long Island NY
631-606-0095
Long Island Home Inspections
Suffolk County Home Inspections
Nassau County Home Inspections
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/5/15, 11:26 PM
Dave Range, CMI's Avatar
Dave Range, CMI Dave Range, CMI is offline
Default Re: Reporting WDO
If it was previously treated and there were no signs of any live termites I would check the box that says the area was previously treated and then check the box that says no recommendation for further treatment.
Hearth and Homes Inspections
440-954-0465
www.homeinspectorofmentor.com
www.euclid-home-inspector.com
www.hearthandhomesinspections.com
www.lakecountyohiohomeinspectors.com
Control your own destiny, or someone else will.
Old 5/5/15, 11:48 PM
Andrew A. Griffin's Avatar
Andrew A. Griffin Andrew A. Griffin is online now
From the rear of the form:
2. Treatment Recommendation Guidelines Regarding Subterranean Termites: FHA and VA require treatment when any active
infestation of subterranean termites is found. If signs of subterranean termites — but no activity — are found in a structure that
shows no evidence of having been treated for subterranean termites in the past, then a treatment should be recommended. A
treatment may also be recommended for a previously treated structure showing evidence of subterranean termites — but no
activity — if there is no documentation of a liquid treatment by a licensed pest control company within the previous five years
unless the structure is presently under warranty or covered by a service agreement with a licensed pest control company.
Andy Griffin
Griffin Inspection Services LLC
agriffin@griffinspection.com
412-407-2501
www.griffinspection.com
www.pittsburgh-home-inspections.com
Pittsburgh home inspections
Old 5/5/15, 11:54 PM
Yeah I know what it says but in this case there is no definitive way of knowing if the treatment was within past 5 years as it is an estate sale of an unoccupied home. I just hate to recommend a treatment for old non-active signs of termites.
Long Island NY
631-606-0095
Old 5/6/15, 8:57 AM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
Tunnels present right it up for treatment , tunnels should have been removed when treatment was done
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Old 5/6/15, 5:16 PM
Marc A. Goldenberg's Avatar
Marc A. Goldenberg Marc A. Goldenberg is offline
Yep. Down here I recommend treatment "if not under a current control warranty".
It protects the consumer and yourself.
<<MG>> State Lic Termite Operator #JF2446
http://www.alltropic.com
Awards Committee Member
The InterNACHI Awards Committee is the final
authority of issuance of any award the committee offers.
