Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 5/12/15, 11:00 AM
Randy Leak, 2700939 Randy Leak, 2700939 is offline
Default Septic System Inspection
Just finished my first Septic Inspection and have a few questions. I always thought the scum layer was almost fluid. The tank I just inspected it is about te consistency of quiche and about 4" thick. Is this normal? The inlet does not turn down, does this require repair? There doesn't seem to be any significant amount of sludge. With this amount of scum is it normal for there to be no sludge?
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/12/15, 11:26 AM
Dave Range, CMI's Avatar
Dave Range, CMI Dave Range, CMI is offline
Default Re: Septic System Inspection
Is the house occupied or vacant?
Was the tank recently pumped?
If occupied, were you able to get the records from the seller of how often they had the tank pumped?
Did you do a dye test on the system?
Hearth and Homes Inspections
440-954-0465
www.homeinspectorofmentor.com
www.euclid-home-inspector.com
www.hearthandhomesinspections.com
www.lakecountyohiohomeinspectors.com
Control your own destiny, or someone else will.
Old 5/12/15, 12:21 PM
Frank Rotte Frank Rotte is offline
You might be in over your head.
Certified Inspection Services, LLC
5521 Mission Road #1422, Bonsall, CA 92003
Check out the HG User Group on FB
ITC Certified Level I Thermographer
Old 6/27/15, 11:34 PM
Chris Jacobi, HI01200061's Avatar
Chris Jacobi, HI01200061 Chris Jacobi, HI01200061 is online now
Send a message via Yahoo to cjacobi
Check out these septic videos.
Video 1
Video 2 <---Best video
Chris Jacobi, CPI
Home Inspections - Termite Inspections - Radon Testing - Drinking Water Quality Testing - Thermagraphy
www.GreatHomeInspector.net
Chris@GreatHomeInspector.net
Facebook
GooglePlus
Serving Indiana from Indianapolis to Greenwood, to Franklin to Columbus to Seymour.
Old 8/3/15, 5:40 PM
Stephen J. Rager Stephen J. Rager is offline
Randy, did you take the NACHI course for Septic? If so, did you find it sufficient?
Stephen Rager
Champion Home Inspection
Serving the surrounding Evansville, IN area
Veteran owned business
Old 8/5/15, 1:16 PM
Frank Blas Frank Blas is offline
I would leave septic to the experts. My guy actually pumps it....save yourself the liability. If you don't pump it you could be responsible for a very costly replacement or repair. Just my two...hope it helps
Old 8/5/15, 1:29 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
To this day I cannot comprehend how anyone can perform a "septic system" inspection without having the tank pumped. I would be like inspecting an electrical panel without taking the cover off.
Stephen Stanczyk
RETIRED
Pierce County -Thurston County - King County - Kitsap County
Old 8/5/15, 1:34 PM
I just had my tank pumped. I also had a great conversation with the guy that pumped it. It was an educational experience for sure. I agree with Stephen,you can't "inspect" without pumping. Read this about pumping your septic tank.
