Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 5/20/18, 8:32 PM
Nick Gromicko, CMI's Avatar
Nick Gromicko, CMI Nick Gromicko, CMI is online now
Default Weld County, Colorado On-Site Wastewater Treatment System Regulations Study Guide.
I'm building out this message board thread to assist those attempting to pass the exam necessary to be an On-Site Wastewater Treatment System Contractor in Weld County, Colorado.
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/20/18, 8:34 PM
Default Re: Weld County, Colorado On-Site Wastewater Treatment System Regulations Study Guide
Definitions:
Absorption System: Leaching field and adjacent soils for the treatment of sewage in an On-Site Wastewater Treatment System by means of absorption into the ground.
Old 5/20/18, 8:38 PM
Basal Area: Effective surface area available to transmit the treated effluent from the filter media in a mound system to the in-situ receiving soils. The perimeter is measured at the interface of the imported fill material and the in-situ soil.
In-situ soil means original soil.
Old 5/20/18, 8:41 PM
Bed: Below-grade soil treatment area with a level sub-base at least 3' wide, distribution media, and more than one lateral.
Note: It isn't a bed unless it has two or more laterals.
Old 5/20/18, 8:57 PM
Bedroom: A room with an egress window, a closet, and/or is intended for sleeping purposes.
Old 5/20/18, 8:58 PM
Building Sewer: Piping that conveys wastewater to the first system component.
Old 5/20/18, 9:00 PM
Cesspool: Underground pit into which household wastewater is discharged and from which the liquid seeps into surrounding soil.
Note: A cesspool doesn't include a septic tank.
Old 5/20/18, 9:01 PM
Chamber: An open, arch-shaped structure providing an open-bottom soil interface with permeable sidewalls.
Old 5/20/18, 9:02 PM
Cistern: Underground tank for storing water.
Old 5/20/18, 9:08 PM
Dosing: High rate, periodic discharge into a soil treatment area.
Old 5/20/18, 9:11 PM
Drop Box: A device used to distribute effluent by gravity flow into a lateral of a soil treatment area.
Old 5/20/18, 9:12 PM
Drywell: Underground pit into which drainage from roofs, basement floors, or other non-wastewater sources is discharged.
Old 5/20/18, 9:13 PM
Effective Size: Size of granular media such that only 10% by weight of the media is finer.
Old 5/20/18, 9:14 PM
Effluent Pipe: Non-perforated pipe that conveys effluent from one component to another.
Old 5/20/18, 9:19 PM
Flow Daily: Measured volume of wastewater generated from a facility in gallons in a day.
Note: Expressed as Gallons/day.
