Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 1/15/19, 3:51 PM
Anthony Defoyd Anthony Defoyd is offline
Default White substance on septic riser
The risers on both the solids tank and the liquid tank have a white substance on them. My pumper thinks it's due to excessive methane gas and suggested adding a vent. The system is a 1,250 gallon 2 compartment tank and the leaching chambers are the newer 3' wide leaching chambers. Can anyone verify the diagnosis and remedy (adding a vent). The set up is a little odd in that the plastic riser lids are both about 12" below grade and had to be dug up in order to remove the lids.
White substance on septic riser-img_8824-jpg   White substance on septic riser-img_9029-jpg
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/15/19, 7:20 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: White substance on septic riser
What a question on a home inspectors forum..
What did it taste like?
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 1/15/19, 7:31 PM
Hi Roy, Just checking, is that not an appropriate question for this forum? I've seen a bunch of septic tanks and risers but never one where both risers have this condition. I really would appreciate any help as I don't want her to dig this up in 5 years and have a collapsed riser.
Old 1/16/19, 8:04 AM
It looks like mineral deposits washing down from above..
#1st Pro Inspection
Old 1/16/19, 8:49 AM
Roy D. Cooke, Sr's Avatar
I agree . Roy Cooke
Old 1/16/19, 3:02 PM
Mark Raumikaitis Mark Raumikaitis is online now
I agree on mineral deposit. Buried riser kind of defeats the purpose. Add an extension to allow better access
Mark Raumikaitis, CMI, NH Lic #133
HomeCheck Professional Home Inspections LLC
Derry, NH
603-432-3211
Inspecting New Hampshire and Southern Maine
http://homecheckhomeinspections.com/
"Always think long term, do not be influenced by short term thinking or rewards."
Old 1/19/19, 6:37 PM
Junior S. Fudge's Avatar
Junior S. Fudge Junior S. Fudge is online now
Haha!
Old 1/20/19, 8:21 AM
Scott Frakes, CMI Scott Frakes, CMI is offline
Anthony,
I'm a little late to the party.....
Seen the white substance in my area but not where its caused a riser to decay. Concrete baffles are another story as I often find them deteriorated or gone.
Simply recommend a riser extension(s).
