Ancillary Inspection Services Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
Old 5/4/17, 8:00 AM
Randall Ryden Randall Ryden is offline
Default zefon z-lite DC powered IAQ sampling pump
Does anyone use this sampling pump?
Is it worth having the battery feature or is it more of a hassle?
Seems like it would be worth having IF it works as advertised.
Having calls for testing of areas without direct power and don't want to waste time running ext. cord.
Any thoughts on this model is greatly appreciated.
Thanks much,
RR
I know enough to know I don't know enough. © 2012
Randall Ryden,TREC #20515
TPREIA Greater Austin Chapter,
Public Relations Director
ABOR
Covenant Inspections LLC
www.CovenantInspectionsTX.com
512.483.1228
Austin, TX area
Old 5/8/17, 11:58 AM
James E. Braun, CMI's Avatar
Certified Master Inspector
Default Re: zefon z-lite DC powered IAQ sampling pump
I use a battery pack with a built in 110v converter such as used to jump a car with. I can run my pump a total of 55 minutes with this battery pack.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
