Old 3/18/13, 2:19 PM
Colton Hagler Colton Hagler is offline
Default 2 water heaters piped together
I've never seen this with two water heaters. The hot water of the first goes to the cold water of the second. Is this allowed?
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/18/13, 2:38 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Default Re: 2 water heaters piped together
Not a problem though I like to see more isolation valves.
As a Professional Home Inspector, I support the privacy of my clients.
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 3/18/13, 2:40 PM
Roy D. Cooke, Sr's Avatar
Yes see ..https://www.nachi.org/forum/f79/two-w...7/#post1002968
Old 3/18/13, 2:44 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
What you're showing is called Series Installation. It's allowed. There are different opinions of it's value of operation.
It's looks like these are 40 gallon tanks. Unless the hot water demand at this house requires that much hot water to be available, you may recommend turning off the gas supply to the upstream water heater.
This link describes both series and parallel WH installation.
http://www.chinawinds.co.uk/diy_tips..._parallel.html
Old 3/18/13, 5:06 PM
Mike Auger's Avatar
Mike Auger Mike Auger is offline
It's OK, a common application is in a multi-unit property. Like a complex where there's one water heater for several units. For a single family likely overkill, but allowed just the same.
Mike Auger, CMI
RI Reg. # 32856
RI Radon Lic. # RMC-142 RMB-096
(401) 578-4878
A U.S.A.F. Veteran Owned Company
Old 3/18/13, 8:35 PM
Joseph Hagarty, CMI's Avatar
Joseph Hagarty, CMI Joseph Hagarty, CMI is offline
http://www.bradfordwhite.com/rightspec.asp
When using the residential sizing, you will find 2 water heaters recommended quite often with larger homes and a family of 4 or more.
Joe Hagarty
mrdryervent@gmail.com
Cell: (484) 883-7018
Boulder, Colorado
Certified CMI Master Inspector Instructor
PA NACHI Certified Inspector # 01102902
PA Licensed Radon Inspector # 2080
PA Licensed Pesticide Applicator # 700884
Delaware Licensed Home Inspector # H4-071
Old 3/18/13, 8:58 PM
Chuck Evans, TREC 7657's Avatar
Chuck Evans, TREC 7657 Chuck Evans, TREC 7657 is online now
Most single family homes that I inspect have multiple water heaters.
Chuck Evans (TREC #7657)
TheWoodlandsHomeInspection.com
Houston, TX
_______________________
Awards Committee Member
Old 3/25/13, 8:10 PM
Richard W. Washington, TREC#7238's Avatar
Richard W. Washington, TREC#7238 Richard W. Washington, TREC#7238 is offline
Typically 3, 3 1/2, or 4 full bath's will have 2 wh's.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Rental water heaters rcooke Canadian Home Inspectors 35 1/26/11 2:32 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
