Old 1/9/19, 9:34 PM
John McDevitt John McDevitt is offline
Default AAVs...Again
Please check out picture. Which drain line do you use to measure the 4 or 6 inch requirement? Is this properly installed? Thanks
AAVs...Again-aav-jpg
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/9/19, 10:44 PM
Emmanuel J. Scanlan, TREC# 7593 Emmanuel J. Scanlan, TREC# 7593 is offline
Default Re: AAVs...Again
It is correct at over 4" above the individual fixture drain ("FIXTURE DRAIN. The drain from the trap of a fixture to the junction of that drain with any other drain pipe.")
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
ICC Residential Combination Inspector
#5247015-R5 (Electrical, Mechanical, Plumbing and Building)
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 1/9/19, 11:30 PM
Thanks!
