Old 3/5/09, 11:44 PM
William Thacker's Avatar
William Thacker William Thacker is offline
Question Air Admittance Valve Under Kitchen Sink
Comments about AAV height in relation to drain height?
Air Admittance Valve Under Kitchen Sink-155-burberry-jpg
Thanks
Old 3/5/09, 11:48 PM
Bob Elliott's Avatar
InterNACHI Applicant
Default Re: Air Admittance Valve Under Kitchen Sink
Was it needed.?
Give us info on location and distance from the nearest plumbing vent.
Was this an island sink?
We can go from there.
Old 3/5/09, 11:56 PM
Originally Posted by relliott View Post
Was it needed.?
Not an island sink. Distance to another vent should not matter in this case. It looks like lazy plumbing to me. A powder room was in an adjacent room less than 5 feet to the right.
My question about comments was more about position to drain height, I suppose I should have specified. The disposal outlet for the other sink side is the horizontal pipe.
Old 3/6/09, 12:13 AM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
Higher than the horizontal, I believe.
Old 3/6/09, 3:06 AM
Chuck Evans, TREC 7657's Avatar
Chuck Evans, TREC 7657 Chuck Evans, TREC 7657 is online now
Certified Master Inspector ®
4 inches above the fixture drain.
Chuck Evans (TREC #7657)
TheWoodlandsHomeInspection.com
Houston, TX
_______________________
Awards Committee Member
Old 3/6/09, 2:22 PM
Originally Posted by cevans View Post
4 inches above the fixture drain. That one's too low.
That was what I thought as well, thank you.
Old 3/6/09, 2:39 PM
Thomas H. Dietrich's Avatar
Thomas H. Dietrich Thomas H. Dietrich is offline
First a HI isn't a Code Inspection.
IRC P3114.4 Location
"Min 4 inches above the horz branch drain."
Photo is cruddy, doen't include the p-trap, so you don't give the full info. So based on this info, is it ok? Guessing from the photo, it's ok. If the AAV is downstream of the trap.
As to why it was used, no photo given, but betting there is a window above this sink. Just a guess. We need photos if you want to ask for good answers.
tom
Old 3/6/09, 10:23 PM
"Min 4 inches above the horz branch drain or fixture drain."
Houston, TX
Old 3/6/09, 10:31 PM
IRC Definitions "Fixture Drain - The drain from the trap of the fixture to the junction of that drain with any other drain pipe."
Now is the AAV min. 4" above the drain from the TRAP?
Tom
Old 3/6/09, 10:57 PM
You are correct.
The fixture drain will be the trap arm, not the drainage outlet of the fixture as I had interpreted. Drainage outlet applies to loop vents, apparently not to AAVs.
Editing previous posts to remove the inaccurate comment.
Houston, TX
Old 3/7/09, 12:16 PM
The P-Trap outlet is visible at the bottom of the AAV, which is more than 4 inches below the AAV. What I gather from the posts: this application is then proper? What about the horizontal disposal outlet pipe?
Thanks
Old 3/7/09, 2:46 PM
Photos? Or do you want us to guess?
Old 3/7/09, 2:48 PM
It is the only horizontal pipe visible in the photo. No guessing required. Click on the thumbnail to enlarge the photo.
Old 3/7/09, 3:12 PM
There is no disposal in the photo so no distance reference. How far away is it? Does it slope propertly, is it leaking?
tom <Guessing>
Old 3/7/09, 3:18 PM
tom <Guessing>
Hi Tom,
The disposal is in the upstairs bathroom.
No, seriously, it is a standard twin bowl kitchen sink. No leaks visible. Probably about 12 inches of pipe with a slight slope.
Sorry I only took one photo F.My.I.
Bill
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing, Ethics & Legal Issues for Inspectors 52 7/11/17 4:34 PM
Shut off valves required? jcahill Plumbing Inspections 11 9/2/08 2:07 AM
Kitchen Sink Plumbing Vent ? fminix Plumbing Inspections 5 3/8/08 10:40 PM
Composite granite kitchen sink ... good choice? Bill Featherstone Plumbing Inspections 6 1/9/08 12:03 AM
waste pump under kitchen sink tjansson Plumbing Inspections 3 5/11/07 3:15 PM
