Old 8/29/12, 9:29 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
Default Boiler expansion tank
Can a boiler expansion tank be postioned up or sideways besides down?
Edit: ...and be operated properly?
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Last edited by lkage; 8/29/12 at 10:27 PM.. Reason: added...and be operated properly.
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/29/12, 10:11 PM
Jeffrey R. Jonas's Avatar
Default Re: Boiler expansion tank
Not sure what you mean by 'down'? Got a pic? I would assume it all depends on how the tank was manufactured. Typically I see them installed 'laying down' like in the first pic from the OP... https://www.nachi.org/forum/f20/why-e...-boiler-43447/
Jeffrey R. Jonas
Owatonna, Minnesota
Old 8/29/12, 10:20 PM
I'm talking about a bladder type expansion tank.
Like these: (#1 down, #2 sideways, #3 down)
~retired~
Old 8/29/12, 11:47 PM
Okay... gotcha. I usually see them in the "up" position, but I don't think it really matters. I was trained that in the up position, any water entering the tank can drain back out by gravity. Seems like there was something about the diaphram failing also, but it's been too long ago. I see less and less boilers every year. I don't miss them at all. Sorry I wasn't much help.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 8/30/12, 12:19 AM
Joseph Hagarty, CMI's Avatar
Joseph Hagarty, CMI Joseph Hagarty, CMI is offline
i have seen expansion tanks installed Up, Down, Sideways....
but.....
what position is Up, Down or Sideways
Joe Hagarty
mrdryervent@gmail.com
Cell: (484) 883-7018
Boulder, Colorado
Certified CMI Master Inspector Instructor
PA NACHI Certified Inspector # 01102902
PA Licensed Radon Inspector # 2080
PA Licensed Pesticide Applicator # 700884
Delaware Licensed Home Inspector # H4-071
Old 8/30/12, 1:35 AM
Cameron Anderson's Avatar
Cameron Anderson Cameron Anderson is offline
I've seen them in every position too, but mostly down. Ask Charlie if it matters, I would guess it may be according to manufacturer's specs.
Cameron Anderson
Integrity Home Inspection
Truth. In Real Estate.
Since 2004
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.homeinspectionpeoria.com
Old 8/30/12, 12:24 PM
Okay, I think it depends on where the put the air scoop.
Here is a Taco Air Scoop:
~retired~
Old 8/30/12, 12:27 PM
~retired~
Old 8/30/12, 1:19 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Please Note: jgromkoski is a non-member guest and is in no way affiliated with InterNACHI or its members.
The primary requirement is that they be adequately supported.
Old 8/30/12, 4:13 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
I agree, the bladder should work in all positions. The air scoop makes a difference.
Any idea why they are almost always down?
Old 8/30/12, 7:34 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
I believe that the most standard installation of bladder expansion tanks on a closed hydronic system would be in the hanging position high above the boiler.
One picture Larry posted could possibly be a steel pressure tank.
Steel Expansion Tanks
The steel tanks are not the most popular – but they are still used in some of the older systems. In this unit the air and the water will touch each other and the air will compress when the water is being heated. The air is than compressed inside of the loop system to create the cushion. It will absorb the excess pressure.
Bladder Expansion Tank
In this tank the air and the water are separated through the use of a diaphragm. This tank is used in the newer systems including the ones equipped with a hydronic loop. The loop helps to control the pressure and must stay at the right level in order to work properly. It helps to install this before the suction side of the circulator pump that is in the supply side of the unit.
Because the bladder expansion tank will absorb the excess pressure inside of the hydronic loop it would help to add the make up water for the unit and hydronic loop close to where the tank is. This will help to keep the pressure relief valve, hydronic loop, and expansion tank at the right settings and with no excess pressure build up.
http://boilerinstallations.blogsavy....n-water-tanks/
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
Old 8/30/12, 9:13 PM
The guys in the field that I talked to say it is because when they get waterlogged they are quite heavy and it is easier to remove from the down position.
~retired~
Old 8/30/12, 11:11 PM
Bob Elliott's Avatar
Although these expansion tanks are meant to be installed vertically, they may also be installed horizontally if properly supported. The RX-60 and larger Radiant Extrol expansion tanks must be installed vertically on the ground and piping can be used to connect them to the air purger and float vent.
http://www.pexuniverse.com/content/h...expansion-tank
Expansion Tank On A Hot Water Heater rmarton Plumbing Inspections 6 2/28/10 3:41 PM
Why is an expansion tank above the boiler? bgromicko Inspecting HVAC Systems 4 9/21/09 11:12 AM
Make $50.00 More Profit per Inspection with Septic Tanks ebeahm1 Ancillary Inspection Services 6 8/20/09 1:38 PM
Water heater expansion tank jfrederick Plumbing Inspections 3 11/17/08 3:35 PM
Water heater expansion tank jfrederick Plumbing Inspections 0 11/17/08 8:18 AM
