Old 6/26/12, 5:15 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Brand new house... 2 story, water pressure is right at 80psi....question
Is this a write up? Or is 80 psi exactly... ok, for new two story house.
David
An Ounce of prevention is better
than a pound of cure :}
www.pyramid-home-inspections.net
Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/26/12, 5:18 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector
Default Re: Brand new house... 2 story, water pressure is right at 80psi....question
Anything 80 or above will be listed in my reports.
Don't report the pressure reading, just report that the pressure within the residence is too high and should be adjusted to around 70 psi. Also note that the regulator may need to be replaced if the pressure cannot be adequately adjusted.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/26/12, 5:34 PM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
The maximum pressure is 80 psi. 80 or below is OK. How accurate is your gauge? I would probably let it ride, especially if there was a pressure reducing valve installed already.
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Old 6/26/12, 5:40 PM
Roy D. Cooke, Sr's Avatar
My house 115 at times +++ .I have a regulator and 35 lb to the home another regulator and 75 Lb to my lawn sprinkler and left a supply for Fire sprinklers I hope to instal soon .
Two different gauges say the same readings .
Old 6/26/12, 5:45 PM
Thanks Jeff...
Old 6/27/12, 12:17 AM
William T. Misegades William T. Misegades is offline
Originally Posted by dnasser View Post
Thanks Jeff...
So does that mean you didn't like Joe's reply?
Where there is a Will there is a Way!
Will Misegades
TREC# 10465
RedFish Home Inspections
www.redfishinspections.com
Infraspection Institute Certified Infrared Thermographer Level I # 9631
"it's not just about how to turn on and tune the camera to make pretty colored spots!"
David A. Andersen, Woodlawn, TN
Old 6/27/12, 10:23 AM
That's the way I took it.
Theodore Roosevelt
Ph: 704-351-1776
Old 6/27/12, 10:49 AM
David OKeefe's Avatar
David OKeefe David OKeefe is online now
Why would you not report the pressure reading?
David
InterNACHI Certified Home Inspector #08051301
NYS Licensed Home Inspector #16000038229
NYS DEC Certified Pest Technician # T4865884
518-505-8305
HouseAbout Home Inspections, LLC
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Connect on LinkedIn
Follow HouseAbout_LinkedIn
Follow me on Twitter
HouseAbout_Instagram
Google+
Old 6/27/12, 11:18 AM
George Russell George Russell is offline
Something I have found. Often in brand new subdivisions or even neighborhoods where they are putting huge apartment complexes the water pressure will be very high until they get up to occupancy then back back down. I have a client who owned a couple of du-plexes in a neighborhood where they were building a huge apartment complex right across the street. When he purchased the units the inspector reported something like 65 lbs pressure. Immediately after the apartment project started I got a pressure reading of 120lbs. Now, almost 2 years later, his pressure is back down around 80.
That being said maybe after more people move into this hood the pressure will drop a few pounds.
George Russell
George Russell Professional Inspections
Lampasas,Texas
TREC # 10215
512-296-9538
http://georgerussellprofessionalinspections.com/
http://www.facebook.com/austinhomeinspections
Old 6/27/12, 11:26 AM
Pressure fluctuates. If it's 80 on the day you were there and the plumber arrives and it's 75, be prepared to pay the bill. Like I said before, 80 is acceptable.
Theodore Roosevelt
Ph: 704-351-1776
Old 6/27/12, 11:34 AM
Like Joe said, pressure changes.
My thinking is a bit different from Joe when it comes to reporting, not saying one is right or wrong.
The way I look at it, the regulator should be adjusted so that the pressure never reaches the "maximum allowable" pressure. If it has reached 80 psi, it needs to be adjusted IMO.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/27/12, 11:39 AM
By the way, I always document the range of the pressure in all my reports. That way if the pressure fluctuates UP and is caught by another inspector at a later date, I documented what it was the day I was there. Could be important in a pre-listing inspection.
Theodore Roosevelt
Ph: 704-351-1776
Old 6/28/12, 2:15 AM
Brian E. Kelly's Avatar
My pressure is cheap, does not have a Mirror Back, and is not Calibrated...I do not note a specific Pressure myself. I do report anything above 80 PSIG though.
"So, what are your thoughts on the Flir One??"
Old 6/28/12, 9:01 AM
Do you report it if the pressure is under 40psi?
Will Misegades
TREC# 10465
Old 6/28/12, 9:12 AM
Many homes in the country are on a well and frequently have about 35 lbs ~.
No I did not report that
Static water pressure question bgromicko Plumbing Inspections 1 1/7/10 10:49 PM
Water Pressure 75 psi .... question dnasser Plumbing Inspections 18 4/4/09 10:03 PM
high water pressure lynn zhou Plumbing Inspections 22 10/25/08 3:56 PM
