Old 9/21/12, 7:59 AM
Curtis Hildebrand Curtis Hildebrand is offline
Send a message via AIM to childebrand
Default Car parts as P trap?
I noticed a foam hose from what seemed like an engine used as a P trap. Clearly the trap depth is more than the required 4" - which I wrote up. But is there any regulation against using foam hoses as plumbing drains?
Car parts as P trap?-img_9563-jpg
Kingdom Home Inspections
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/21/12, 9:50 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector ®
Default Re: Car parts as P trap?
Plumbing components must be manufactured and listed for their specific purpose. I have seen listed fittings and traps which are rubber, although I don't "like" them. I can't say by looking at it, if yours is one of those listed traps.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/21/12, 1:58 PM
Jeffrey R. Jonas's Avatar
InterNACHI Applicant
There are many products on the market deemed for "emergency use". There is nothing to specify how long an emergency may last. Write it up, and carry on.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 9/21/12, 2:28 PM
Only time I have ever seen drain with traps like the one you show is in a beauty palor / barbershop and once in a house at a kitchen sink. The theory was that in event of a clog it could be squeezed or manipulated to quickly and easily dislodge whatever was causing the clog. I do not know if I buy that story but there it is.
Old 9/21/12, 2:30 PM
Humberto Carvajal, HI884's Avatar
Humberto Carvajal, HI884 Humberto Carvajal, HI884 is offline
This may be similar to what you have....
http://www.dyersonline.com/mission-rubber-p-trap.html
Bert
<div align=left><a href=http://www.afloridainspection.com target=_blank>[SIGPIC]
Humberto Carvajal Jr.
Florida State Property Inspections, LLC
Florida Home Inspector License# HI884
LEED® Accredited Professional
Member USGBC South Florida Chapter
Old 9/23/12, 12:36 PM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you look at the logo you will see it has a CSA approval as any part sold in Crappy Tire or Home De pot. This is not approved however by most plumbers for installation.
As J J said write it up and carry on.
Condensation Drain line question acassady Inspecting HVAC Systems 26 10/23/14 11:17 AM
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 80 12/6/13 4:21 PM
S-Trap? Part2 wmisegades Plumbing Inspections 9 12/12/11 9:07 PM
Trap weird and crown weir dpant Plumbing Inspections 22 1/25/11 12:41 AM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/15/06 12:00 AM
