Old 10/16/12, 12:30 PM
Bob Elliott's Avatar
InterNACHI Applicant
Default Cast iron to copper
Cast iron to copper-dsc01014-jpg
What say you?
Does this need some type of special coupling ?
Is there another type besides the typical rubber with hose clamps part if needed or is copper to cast iron not as big a deal as a water supply ?
I know brass to either is OK for the most part.
Had these transitions all over the basement as well.
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/16/12, 12:44 PM
Joshua L. Frederick Joshua L. Frederick is online now
Default Re: Cast iron to copper
As long as the CI hub had a seal or there was separation from the 2 diff metals, I don't see a problem with it. Looks professional/right way to do it to me. I usally see ferncos, which is o.k., too. Was there any evidence of electrolysis anywhere?
Old 10/16/12, 1:00 PM
copper had green at many connection points but did not see corroded or leaking.
Lots of transition points however so covering my bases.
Not all had hubs.
May focus on those.Thanks.Dumb question but distracted today .
Light Switch Near Shower vsantos Electrical Inspections 240 11/17/14 12:50 PM
Total galvanic reaction? jtribuzio Plumbing Inspections 19 4/3/10 3:18 AM
PVC to Cast Iron - No flexible connection mmixson Plumbing Inspections 1 7/29/09 2:29 PM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services 2 2/18/06 12:22 PM
