Old 3/2/13, 5:12 PM
Paul Maggiore's Avatar
Paul Maggiore Paul Maggiore is offline
Default Cast Iron Drain Pipe - Life Expectancy
Inspected a home here in Florida yesterday, original iron drain pipe, constructed in 1960. Observed a previous repair to the pipe at guest bath(above slab). Significant rust. Got me thinking about the life expectancy which I've read is 50-60 years, correct me if I'm wrong. When you old salts inspect a house like this do you write up the fact the drain lines may be nearing the end of their useful life? I mean typically I don't get a view of the drain lines, either concealed in wall or under slab. Any input is appreciated.
Paul Maggiore, CPI, CGC
Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/2/13, 5:19 PM
Roy D. Cooke, Sr's Avatar
Default Re: Cast Iron Drain Pipe - Life Expectancy
Yes
Cast iron drains are close to the end of their life and are prone to leak at any time .
Recommened budget for immediate replacement .
Old 3/2/13, 6:59 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
http://psinspection.com/blog/?p=692
and;
Longevity
  • Although PVC and clay became the piping material of choice a few decades ago, because of the long life span of cast iron, some homes and buildings from the 20th century, and even earlier, are still equipped with this type of sewer line. Good quality, thick cast iron piping, installed under idyllic conditions can last from 75 to 100 years and beyond. Manufacturers now make ductile iron sewer pipes and fittings, but in contrast to cast iron installation of the past, the new metal waste disposal system is as quick and easy to mount as PVC sewer piping.
Read more: What is the Life Cycle of Cast Iron Sewer Pipes? | eHow.com http://www.ehow.com/info_12173619_li...#ixzz2MQhHCqnk
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
Old 3/2/13, 7:54 PM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
I simply put cast-iron and galvanized piping will rust from the inside to the outside and eventually will need updating. If mineral deposits are noted as reported as a leak. Also be aware I have found vent pipes totally rusted out behind the wall. Typically you will smell an odor in the bathroom if this occurred.
Please note if you had Sean Fogarty working with you it may be just that he dumped the load forgot air freshener.lol
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Old 3/2/13, 7:58 PM
Dam that sounds potent.
Old 3/2/13, 9:33 PM
Thanks guys
Condensation Drain line question acassady Inspecting HVAC Systems 26 10/23/14 10:17 AM
PVC to Cast Iron - No flexible connection mmixson Plumbing Inspections 1 7/29/09 1:29 PM
Is this allowed? belliott Plumbing Inspections 4 7/15/09 6:40 PM
TPR Drain pipe mwood1 General Inspection Discussion 18 3/10/08 6:05 PM
