Old 7/9/12, 12:34 PM
Joe Funderburk, CMI's Avatar
Certified Master Inspector
Default Copper gas tubing at manufactured fireplace
Anyone know of a requirement to sleeve copper gas tubing where it enters the sheet metal enclosure of a manufactured fireplace? I see it sometimes and suspect that certain jurisdictions require it, but I can't find a code to require it in the IRC. Personally I don't see the need for a sleeve there.
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/9/12, 2:00 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Default Re: Copper gas tubing at manufactured fireplace
This is not a code compliance message board...
However, I feel that:
All plumbing penetrations should be sleeved (in my opinion), if they are subject to potential damage.
But there are a lot of "Barney Fife Inspectors" that can help you out here...
Clarksville - Nashville Home Inspector Lic#40 (Retired)
BPI# 5015804
Old 7/9/12, 3:05 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector ®
Not required in my jurisdiction, because copper is not allowed for natural gas distribution
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Los Angeles, Santa Clarita & Antelope Valley CA
Old 7/9/12, 3:30 PM
Some inspectors around here write it up. I'm not sure why. There is no vibration so what is the potential damage possibility? There is no exposure to corrosive materials, no chance of a galvanic reaction.
I don't believe in recommending repair based on 'Joe's Law.'
Theodore Roosevelt
Ph: 704-351-1776
Old 7/9/12, 3:31 PM
That same pipe likely touches various other materials as it snakes through the house. Why sleeve it here?
Theodore Roosevelt
Ph: 704-351-1776
Old 7/9/12, 7:23 PM
Barry Adair's Avatar
Location: this side of Texas dirt, another successful day
not sure if this is what you needed
regardless of gas supply pipe material
most mfr require seal at entry through firebox
check install instructions ymmv
Copper gas tubing at manufactured fireplace-gas-line-firebox-sealed-jpg
badair
ADAIR INSPECTION
972-487-5634
Commercial-Residential-Construction-EIFS/Stucco-Infrared Thermography
TREC # 4563
EDI: EIFS-MA TX # 39
National Association of Commercial Building Inspectors & Thermographers™ Member ID 12011-14TX
life is the random lottery of events followed by numerous narrow escapes...accept the good
Old 7/9/12, 7:59 PM
Why is the damn sewer line sleeved?
1. It's not ours to question why.
2. It's not our damn job to determine what the code is.
BPI# 5015804
Old 7/9/12, 11:46 PM
Bruce A. King's Avatar
Could be a habit since they sleeve it for csst. CSST manuf now recommends keeping the pipe a certain distance from other metal. The prefab metal boxes usually have an electrical outlet underneath that may be bonded to the fireplace.
www.BAKingHomeInspections.com
Serving Charlotte NC area and Fort Mill SC areas.
License NC2449 and SC1597
Old 7/10/12, 9:05 AM
To prevent direct contact from the foundation on the sewer pipe. Reduce the possibility of cracking. But I digress.
Theodore Roosevelt
Ph: 704-351-1776
Old 7/10/12, 9:07 AM
I ask because a local inspector inspected a property I did a pre-listing inspection on and he wrote up the absence of a sleeve on a copper gas tube (Bruce, he has a name similar to yours). Seems like we all agree there is no requirement (other than possibly the fireplace manufacturer's).
Theodore Roosevelt
Ph: 704-351-1776
Total galvanic reaction? jtribuzio Plumbing Inspections 19 4/3/10 2:18 AM
copper bar Unregistered AskNACHI.org Inspection Questions Forum 14 6/28/09 10:10 PM
10 Yrs old house Soft Copper tubing in attic for fireplace? crichiii Plumbing Inspections 2 6/6/08 5:42 PM
10 Yrs old house Soft Copper tubing in attic for fireplace? crichiii Plumbing Inspections 2 6/6/08 12:23 AM
