Old 10/14/12, 7:43 PM
Mark Karson Mark Karson is offline
Please Note: Mark Karson is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default CPVC vs. PEX pipe question
Hello. I'm installing an reverse osmosis system for my bathroom. I am mounting the system directly below the bath in an unfinished slab, as this means not having to make room in the crowded under-sink cabinet, and also keeping the stored water a few degrees cooler.
My question is regarding the PEX pipe. My kit came with CPVC pipes, some of which will be too short for this location. I haven't yet found a local retailer who sells the same stuff, but the local PEXMALL.COM store carries PEX. From a quick check on some sources, there don't seem to be many differences from an end-user perspective - other than the pressure ratings, which should not be of any importance in this scenario. Is there any reason I should keep hunting for CPVC, or will PEX be suitable?
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/14/12, 8:00 PM
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
Default Re: CPVC vs. PEX pipe question
It sounds like PEX would work fine.
Awards Committee Member
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 3/13/13, 9:41 AM
Robbie Roth Robbie Roth is offline
Please Note: Robbie Roth is a non-member guest and is in no way affiliated with InterNACHI or its members.
I couldn't find how to make a new post so figured I'd try this. My house has a slab leak and is getting repiped and due to lack of space in attic we want to dig a trench and run the pipe around the house. We've had plumbers say they were going to use cpcv pipe and others wanted to use pex pipe. Is one better then the other and is it okay to put the pipes around the house like that instead of through the attic? TIA
Old 3/14/13, 9:42 AM
Chris l. Kenyon's Avatar
Chris l. Kenyon Chris l. Kenyon is offline
Send a message via Yahoo to ckenyon
It may not be a problem in florida, but in northern arizona cpvc is no good due to freezing temperatures this pipe tends to shatter. I have installed miles of pex with no problems.
Identify ABS defective pipe mcyr Plumbing Inspections 11 11/18/15 10:42 PM
1/4 cpvc pipe Phil Narron Plumbing Inspections 7 7/23/12 10:43 PM
Modular pipe insulation question jdamato General Inspection Discussion 7 6/4/11 12:12 AM
