Old 9/30/12, 6:45 PM
Juan C. Jimenez Juan C. Jimenez is offline
Default Well crack
When ever there is a well and septic system at house I always tell my clients that well and septic inspectors are separately licensed and regulated and that they will need a separate inspection. That doesn't stop by curiosity though.
What are some reasons why the septic alarm would be going of?
Is this a crack a problem?
I just wanted to give a shout out to Troy Pappas for answering my question about the alarm while I was at the inspection. Thanks man!
Well crack-holzschuh-004-jpg
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Richmond Chimney Sweep
Richmond Radon Testing
Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/30/12, 7:20 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector ®
Default Re: Well crack
Usually a septic alarm is the result of a "high-water event," meaning, the pump system is failing or can't keep up with the influx of water/waste.
The crack in that well housing is only an issue if the water level is up there, which is usually not the case.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/30/12, 7:24 PM
Thanks Jeff!!
Juan Jimenez
God. Family. Home.
804-269-4321
Old 9/30/12, 7:34 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Well casing in this State are all steel, concrete is used for hand dug wells which are few these days.
What kind of well casing was that?
Oops, thought that was a well casing.
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
Old 9/30/12, 7:41 PM
I have no idea. I make my clients very aware that I know only the basics of well and septic systems and that they will need a separate inspection. I actually make my clients well aware of all limitations involved with my inspection.
Juan Jimenez
God. Family. Home.
804-269-4321
Old 9/30/12, 7:44 PM
Juan, edited my post above, thought your picture was a well casing.
I guess that was a septic tank access?
Old 9/30/12, 7:54 PM
Yes it was the riser. There was another tank access as well. It was level with the ground and had a green lid. I hadn't seen one like that before. They are always like the ones in the photo that I posted. I haven't done many inspections with private waste systems though.
Juan Jimenez
God. Family. Home.
804-269-4321
Old 9/30/12, 8:02 PM
I don't do well and septic inspections either.
Too much involvement to do it right.
Old 9/30/12, 8:04 PM
Agreed
Juan Jimenez
God. Family. Home.
804-269-4321
Old 9/30/12, 10:13 PM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Below is what I would have reported in this situation.
· For The Record: Well cover and gaps at tiles (surface/shallow well) should be sealed for the first eight feet to prevent surface water from entering. Water should be encouraged to filter through the ground before entering well to remove contaminants.
On The Level Inspection
Gatineau, Québec
Old 9/30/12, 10:32 PM
You reports say "for the record"?
Juan Jimenez
God. Family. Home.
804-269-4321
Old 9/30/12, 10:53 PM
I disclaim well and septic's in my reports but will provide information like for example vermiculite in attic. For The Record is one of the conventions I use in my reports.
For The Record: Represents educational-type comments meant to help the client better understand how things work within the home. It may also be used to warn the client about potential problems, or inform the client of certain inspection limitations. Typically, no action is required.
Well crack-1513-jpg
Gatineau, Québec
Old 10/1/12, 8:04 AM
Peter C. Russell's Avatar
Juan,
If there is a tank alarm it must be for a pump station. Pump stations are used to pump the effluent up to the EDA (effluent disposal area).
These types of systems are used when gravity fed systems wont work, usually because it's a raised bed due to the water table or the effluent is pumped to a different location.
It sounds like in your case the green cover is the treatment tank access and I assume the tank in your picture is the pump station.
As waste leaves the house it goes to the treatment tank where the solids settle to the bottom. As the effluent level rises in the treatment tank it is gravity fed to the pump station, most residential stations are 500 gallons. The pump inside the station will activate once the float reaches a certain level. Many time this is determined by the designer. This is determined so the EDA receives a certain number of doses per day such as 200 or even 300 gallons per dose.
As Jeff pointed out, if the alarm is sounding, it's because the float is either stuck or effluent is not leaving the pump station. This could be due to a failed pump, a clog somewhere or a saturated EDA that will no longer drain.
Hope this helps.
Russell Inspection Services LLC
New Hampshire state license # 57
New Hampshire licensed septic evaluator # 18
Level II Thermographer, ITC
Building Science Thermographer, ITC
Commercial Inspector, ITA
www.newenglandthermalimaging.com
www.russellinspectionservices.com
www.nhsepticinspection.com
www.nh-commercial-building-inspector.com
Serving Alton, Alton Bay, Wolfeboro, Laconia, Gilmanton, Gilford, Meredith, Center Harbor and the entire Lakes Region
Old 10/1/12, 8:09 AM
That does help! Thanks Pete!
Juan Jimenez
God. Family. Home.
804-269-4321
Old 10/1/12, 10:49 AM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
That's not a well casing. It's a well cover. The crack is not a concern. This one isn't "water proof" either.
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Vertical crack in foundation - concerns? Jason Wang Structural Inspections 8 2/20/12 11:14 AM
Foundation crack ? Jason Bloxom Structural Inspections 9 3/16/09 1:32 PM
Crack Control Joints aroncone Canadian Home Inspectors 3 11/20/07 8:49 AM
Diagnsing a V crack dmacy Structural Inspections 16 4/20/07 12:14 PM
